Originally Posted by Tmansdc
Hey everyone! Me again! This time can anyone here tell me exactly what the best settings would be for the following?
Can anyone please tell me also for the hdmi ones which resolution is best to pick? DVD is of course 480i/480p and 360 is mainly 720p native. I don't know the scaler quality of the tv.
Thank you all so very much.
NOTE: BEFORE doing any video adjustments, it would be best to do an
"INITIAL RESET" found in the
OPTION Menu. Or at least, do a
Picture Reset in each Picture Mode setting you are going to use. "INITIAL RESET" would be set though, rescan your channels, and go from there.
You have quite a mix there! For anything that uses component video connections I would recommend one of the presets. I'll include a few at the end of this post. The main thing is you want to keep back light down as low as is possible with your normal room lighting. At night, you can set the back light down by using the Energy Saving remote button and set it at Minimum or Medium or whatever suits your taste. Low back light gives the best black level performance.
For your Sony DVD player try the HDMI Expert2 Cool Sony S550 setting.
I'll also include an OTA settings which many use here on there TVs and seems to work well.
For SD cable, use a Preset like Standard or Sport and maybe try Picture Wizard, because with SD it just isn't very significant.
As a general rule of thumb, besides keeping back light low, Contrast is best in the low 80s (81 -83) and Brightness in the low 50's (50-53). Color should be good at 50 also, with Tint at O. For presets, make sure you have Color Temp set at W45 to W50 or so.
Lastly, make sure you turn off Energy Saving before making any adjustments.
For more pertinent settings regarding XBox 360 use the search tool at the top right of the thread page here.
Â
LG 42LD550 OTA_Cable ISF EXPERT2 Pre Medium 2-10-11 Usable Range.txt 1.2763671875k . file
Â
LG 42LD550 OTA_Cable Game (User) 9-10-10.txt 0.728515625k . file
Â
LG 42LD550 OTA_Cable Standard (User) 9-10-10.txt 0.7314453125k . file
Â
LG XXLD550 HDMI CINEMA (User) PICTURE 12-4-10.txt 0.6416015625k . file
Â
LG 42LD550 HDMI 1 EXPERT2 COOL Sony S550 FINAL 2-17-11 Usable Range.txt 1.458984375k . file
