AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official LG xxLD550 xxLD520 xxLD650 Owners Thread
Official LG xxLD550 xxLD520 xxLD650 Owners Thread - Page 34
post #991 of 5047
Originally Posted by dserban View Post
Mine came with a CD but is for PC only. Anyone knows if there is a Mac alternative?
A google search for "dlna server for mac or linux" shows up:
http://www.rbgrn.net/content/21-how-...-os-x-or-linux
that lists a bunch of alternatives, including many free ones.
post #992 of 5047
How can I delete DigitalTV channels on a LD550 ???
post #993 of 5047
Go into menu, select Channel, select channel edit. Follow the icon buttons functions on the bottom of the screen.
post #994 of 5047
Originally Posted by Phase700B View Post
Hi and congratulations on the new TV.
Some of your concerns are notable and seem common among the 32LD550 regarding the cable box "stutter" and also the light bleed. Regarding the light bleed it seems 32" LCD panels are more prone to it. Since it's Costco, I would try another unit, plus, when you do try and ask/get one with the "W" in the little white model label on the box. Example: 32LD550 -UB.CSUWLH This will assure you get an IPS panel.
To enter the different IRE points, make sure you have 10 Point selected in the "Method" menu setting. Then make the first RGB entry at IRE100, step back up to 100IRE and left arrow it to ge to 90 IRE and make its entry, and so on.
If you want more pop and color try increasing color a bit but not to where reds glow or bleed. Also, you can try using the Medium setting for Dynamic Contrast especially for Daytime use. Lastly, you can set backlight up to a max of 35, but I would not recommend more.
Hope this helps. As far as the stutter goes, try turning off TruMotion, and also try a different setting for Real Cinema if it is avail able.
Thanks so i figured out the IRE, but i have to say the whites dont seem as white as i would like them to be. What should i adjust to get the the whites to stand out more? They have like greyish hue to them with your settings on my cox hd-dvr box. I also got new cable box and so far havent seen any jittering. Will continue to monitor it with the new box
Lastly i got the walmart lg player sale the BD530 for $65 and i cant complain for the money. It's decent, watched Cats & Dogs last night and the clarity was great. One thing I didnt like is how low the volume is, i had to almost max out the volume to hear the blu ray. Obviously I should invest in getting a sound bar or better speaker system, but is there a setting that could help in the mean time?
post #995 of 5047
If I just hit the OK button in the middle of the remote, it flashes at the top of the screen 1080/60p if it's DirecTV. If it's my blu ray, it shows 1080/24p.
post #996 of 5047
Oops. That was a reply to a post from several screens ago. I should have quoted it - sorry.
post #997 of 5047
Just took delivery on my 42LD520 a couple of days ago. It's in my basement, which can be as dark as a cave even in the daytime. I copied these settings from a post somewhere, but I don't know where. Forgive me if I've plagiarized somebody - I obviously did, just don't know who LOL! Anyway, these seem to work pretty well for me in a dark room for just about everything.
Aspect Ratio 16:9
Energy Saving Off
standard mode
backlight 40
contrast 75
brightness 54
sharpness 40
color 60
tint 0
temp C10
dynamic contrast off
dynamic color off
clear white off
skin color 0
noise reduction off
digital noise reduction off
gamma high
black level low
eye care off
real cinema off
color gamut standard
xvYCC off
truemotion off
post #998 of 5047
Originally Posted by absoluteczech View Post
... One thing I didnt like is how low the volume is, i had to almost max out the volume to hear the blu ray. Obviously I should invest in getting a sound bar or better speaker system, but is there a setting that could help in the mean time?
Your bluray player might have an audio config setting for whether to normalize or compress audio levels. If you find such a setting, if it's off or set to a wide range, turn it on or set it to a narrower range.
I also noticed that the various audio modes on the TV itself (42LD550 in my case) could vary the volume quite a bit without touching the vol +/- button.
post #999 of 5047
I picked up 2 BD530s and 2 BD550 for $75 each also. Still comparing them both. I do like the increased NetCast features on the BD550, and the picture is a tad better than the BD530, but not by much.
Ok, on cable boxers and things liek DircTV and Dish, there are always kind of "weird" differences in the video signal from them. I always got a hazy over shadow on my Dish, and about the same on DirecTV with some blue tint to it.
That said, try the Expert2 settings, if that doesn't work try decreasing the R (red) a point or two ( or just leave and increase blue), and INCREASING the B (blue) a point or two at IRE 100, 90, and maybe 80. Do this only a point or two at a time, then check your results. It would be best if you can do it on a still image or something like hockey or that you are familiar with. Remember though, "white" is rarely "pure" white even on ice or white backgrounds. What I would do it have Expert 1 set a little warmer than Expert 2. Then use either depending on what you are watching. Why? Because D65, or 6500K, is the color temperature of natural light. There are many posts in this thread where I explain this. The only place you might want a "pure" white" color setting is for video games, where it's all artificial anyway.
Why is this important? As soon as you start getting away from natural white, which is actually an "off white", the other colors will be off. What's the big deal with that? You will lose realism and the almost 3D look to movies and sports images. If you set Expert 2 up like I just said, by tweaking the red/blue and leave Expert 1 with a bit of off white to it, you will see this when a high quality movie is on.
If you want more info on this, do a search on the main page here on AVS or Google ISF calibration and 6500K color temperature. The bottom line is, a too bright, snappy picture draws the eyes attention for awhile, but if a TV is set properly, the images should look pretty much the same brightness and color spectrum as if they were in the same room you are in.
Hope this helps! The LG BD530 can;t be beat for the money I don't think. Enjoy!
post #1000 of 5047
-Move
-Lock/Unlock
-Skip
-Add/remove favourite
-Favourite group
There isn't DELETE here, nor in Radio channels. But there is on AnalogTV.
I've also checked on a friend's LD320 and it's the same.
Very strange. ¿Maybe this option can be enabled on service menu?
[NOTE: DigitalTV I mean DVB-T]
post #1001 of 5047
-Move
-Lock/Unlock
-Skip
-Favourite group
Your menu ia entirely different than U.S. models. You need to look for this info in a forum for Euro LG products.
We have no "Radio Channels" in our U.S. model LG televisions.
Sorry, but this is just another example of difference in markets.
Try this website and select "Manuals & Documents:":http://www.lg.com/uk/support/product...oduct-profile#
post #1002 of 5047
I just got the 46ld550. The TV is connected to the Sat DVR via HDMI and optical sound out to an AV receiver. My question is, how do I enable it to pass through Dolby 5.1?
I tried every sound function but there is none to enable the pass through.
Is it not possible with this TV?
post #1003 of 5047
I got a 42ld520 and am having issues with video on my computer. The player runs really funky in fullscreen and I think I finally realized it is actually the tv not the player or my files. I'm assuming it's being weirded out by the 120hz, for whatever reason, as it's kind of slower/jittery randomly as a video plays and looks fine on my second monitor(60hz lcd monitor). I'm using an ATI video card, so catalyst control center, and if I turn my output to 24hz it does fix the problem, though introduces a bit of messed up color(just slightly) in the videos, which I find weird. Not to mention I don't want to constantly switch back and forth, that setting is atrocious just to even use a mouse on the desktop. What else can I do?
...Actually I'm not sure if putting the computer at 24hz output is helping, but this is really annoying. As I said, I -know- it's not the player or files because after testing two players on multiple files, the only thing that made them playback smoothly was putting it on my second monitor. Help?
post #1004 of 5047
How do you have the two monitors setup? Since you refer to putting the playback on one monitor or the other, you're presumably using an extended desktop rather than cloning?
Sometimes video might play back well only on the primary display but not the secondary.
You might also want to verify whether the somewhat ridiculous-sounding Avivo Video->Video Playback->Enforce Smooth Video Playback option is set for the second monitor (why would you NOT want smooth video playback? :-).
post #1005 of 5047
how is the PC hooked up to the TV? DVI->HDMI, VGA->VGA? Depending on the port the TV may handle the signal differently. you can try turning on "game mode" if it lets you which will force it to 60Hz and try turning off all post processing on the TV side. you want to get it as close to as a regular "monitor" as possible to try to find the cause.
Note: 120Hz on these TV's is an internal rate. The actual input ports and what the PC will see and use is standard 60Hz.
post #1006 of 5047
What do you mean by "messed up color"? Something I just noticed, that I was coming here to post about, is that if you change to 24hz or 30hz via the computer, the TV sees it as a new component and resets all the picture settings. I noticed the color completely changed when I switched to 24; you'll have to enter the settings in again and then it'll remember as you switch back and forth.
Hopefully that's all you're experiencing.
post #1007 of 5047
for what its worth I use my computer at 60hz and the tv has never really had a problem with it at all.
post #1008 of 5047
Phase700B thanks for you help with the settings...I like the 47LD650..With the settings you posted..Looks damn good...
post #1009 of 5047
I currently have a Panasonic TCP58S1 plasma. Mainly use it for auto racing and movies. Am considering the LG 60LD550. Will the picture quality be an upgrade from the Panny? Are there any motion blur issues?
post #1010 of 5047
Picked up the 60LD550 -- should be arriving sometime early next week. This is replacing a LN32B550 Samsung as the main TV that I got last year...I hate to beat a dead horse but how is the input lag on the 550s? I've heard a lot of praise for the 450s, but still have yet to see anything definitive for either.
Also, MrVizio or VBB -- can either of you post a photo of the pixels close up? It might demystify a little bit about what tech is being used on the panel, I don't think that was discussed in debt. Thanks.
post #1011 of 5047
To save me from reading 34 pages...
What panel is used in the ld550(particularly the 32'')
Is there a panel lottery for this tv?
If so, how do I get an IPS(assuming it's available)
Any quirks or things I should know about before trying to use this as a monitor?(I understand/forgive the bad dot-pitch ratio that goes for any 32'' 1080p screen..)
Thanks in advance.
post #1012 of 5047
Thanks, and glad to hear the settings helped you get a great picture!
I missed a great deal on a 47LD650 and sometimes wish I would have gotten one.
post #1013 of 5047
Thanks in advance.
Check the box it came in for the model number sticker. The number you are looking for is right nex to the model number and will designate what panel you likely have: 32LD550 UB.CUSWLH
The W sigifies IPS panel.
post #1014 of 5047
If you read back a few posts, one new owner said that he could see the label on the back of the panel for his 55" or 60" and it was made by Sharp. Do not know what kind of panel though.
post #1015 of 5047
Ah, completely missed that on page 31 (firedog79) -- it looks like these panels may be a variant of VA then. Thanks for pointing that out.
As long as it's not TN, that would be a slap in the face.
post #1016 of 5047
I have a 47LD650 also. Which settings from Phase700B did you used? I'm having trouble calibrating mine.
post #1017 of 5047
Originally Posted by xjeffreyxnothing View Post
Does anybody know if there is any way to tweak the white settings of the 47ld650. I swear if I dont fix the fuzzies on this tv soon I am going to throw it out the window
I'm getting " fuzzies " also on my 47LD650...especially when watching sports. Have you been able to find a setting that reduce it a bit?
post #1018 of 5047
Dear members, home theater noob here. I can get a LG 42 ld520 or a Sony 40EX400 & a Vizio VSB200 for XMAS gift as a black friday purchase. Both options are the same price. Wife says if I get the lg I can get a 5.1 system in the spring. Thanks in advance and Happy Holidays.
post #1019 of 5047
Thanks phase700b!
post #1020 of 5047
Ok sorry, really busy, and maybe I'm a little used to it but I wanted to make sure it continued happening. A bit harder to pick out now. Anyway...
It's dvi to hdmi. I understand the computer isn't outputting at 120, even if it was the tv isn't going to actually display 120 frames a second, like in a pc game, I just figured it had to do with that or some kind of processing effect. Had a 40'' samsung before, Ln40 something or other, and this problem didn't exist with that tv, and I did read some problems of video playback with new owners of a 120hz set.
That's possible, I didn't mess with anything on the tv when switching back and forth between 24 and 60 settings on the computer as I mainly did it to test and didn't leave it there for a long time. It could just be the tv resetting itself to a different setting than what I had before.
Extended desktop, the tv is my primary display anyway. For the tv that setting is already on, whether it's working or not though...
I thought I did change my tv to game mode for the computer input when I first read these responses, but hadn't. I'm going to watch some stuff right now anyway so I'll see if that makes it look better. Looking for anymore help if this doesn't do the trick, thanks.
