AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Just bought Samsung PN58C550, help w/playing DVDs
post #1 of 9
Hello all,
I just purchased a Samsung PN58C550 Plasma. So far, it appears to be a fabulous display: fantastic picture, no "buzz" issue. I've done searches on this subject but haven't come to any conclusions yet so thought I'd start a new thread.
I have a decent collection of DVDs and I'm about ready to take the plunge on a Blu Ray player. I'm wondering what the general consensus is on the best way to view regular DVDs on a high-def display. My searches thus far have led me to believe that using a Blu Ray player with good upconversion is the way to go in the more reasonable (say, up to $500) price ranges.
Right now I'm leaning towards the Panasonic DMP-BD85 which seems to be fairly well respected and has all of the features/flexibility I would like. I'mn also considering the Oppo BDP-83 as it sounds like the "cream of the crop" for reasonable money. However, it lacks many of the features of newer players (mainly the wifi stuff). The Samsung display does have wifi capability, however, so perhaps this is not an issue. I assume I can use that for streaming Netflix, YouTube, etc. Is that a correct assumption?
In any case, any advice would be greatly appreciated as to how to get the most out of my DVDs with the new display. My current DVD player is a Denon DVD-2910. Is there any scenario under which the Denon might be a good choice (e.g. just change some internal settings on the Denon and connect right to the Samsung via HDMI or some such arrangement)?
Thanks very much,
Joe
post #2 of 9
dont know if this is true or not but i read a while back that sony is makeing
a top of the line blu-ray player called an elite? it has 24p play back or something like that
like isaid iam just geting back in to tv tech so iam learning
post #3 of 9
Thank you.
Anyone else? Is the the wrong forum for this thread?
Joe
post #4 of 9
You should post in the BluRay player forum. Your 2910 is an excellent upscaling player. Whether a new BluRay player does a better or worse job upscaling SD DVDs depends on the specific BluRay player (many may do a slightly better job, and some may do a worse job). Personally, I would only buy a new BluRay player today that has Netflix streaming capabilities. But you have to decide which features are most important to you.
post #5 of 9
Thanks, Bill. I appreciate the help.
post #6 of 9
For upscaling, whether from the Denon or a BluRay player, you just need to connect via HDMI and set the output resolution to 1080p (if the Denon does not output 1080p, then set it to 1080i).
post #7 of 9
honestly OP.. i would just get a PS3.
outputs in 24hz
post #8 of 9
outputs in 24hz
When it came out, it was a great choice. IMO, there are many better players available now (with better upscaling), at a lower price than the PS3.
post #9 of 9
Even though you do not need the 3D functionality, you may want to read this review as it gives you an option for a more current player with a lot of features at a lower price point than the Oppo, which is very good.
http://www.hometheatermag.com/3d-blu...ray_3d_player/
