Budget is $500 to $600 dollars. At A4L, the Onkyo is $499 refurb / $599 new right now, and the SR6003/6004 are $499 and $599 refurb, respectively.
Associated gear: Oppo BDR, Dish HD-DVR, Logitech Squeezebox 3, xBox 360, Mitsubishi 720P DLP TV (plan is to upgrade to 1080P flat panel later this year), 5.1 speaker set up
I'm very concerned with all of the bad press the 6004 is getting due to the "POD", so I'm pretty sure that's off the list unless somebody can assure me the issue's been corrected.
I listen to music 75% of the time, and watch tv/movies 25% of the time, although that may shift a bit when I upgrade the TV and can unleash the full power of the Oppo. I want to use the video processors on the Oppo, and the DVR and xbox both will be connected via HDMI, so I don't think video processing capability is a major concern. (I'm assuming that all of these receivers can pass the video through from the source to the TV via HDMI without "molesting" it. Please let me know if that's *not* the case).
My preliminary conclusion is to go with the SR6003, because of Marantz's reputation for stellar sound, and the quality issues on the 6004. But after perusing this board for a couple of weeks, I'm even more confused about current AVR's then when I started, so I thought I'd throw this out there and try to get a little reassurance before I pull the trigger. Any thoughts, opinions, or comments would be much appreciated.
Rob
PS - I do not plan to go with 3D capability on the new TV, so that is not on my radar at all
Rob
