AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Projector Setup Help
post #1 of 3
So I am trying to learn what I can about throw distance and screen size along with seating position and how it all works together to influence your viewing experience. Below are the dimensions of the room I am using. The seating may not be dead center but I will do the best I can. I would like for the projector to be at the back of the room as I will not be mounting it but it will instead be on the top of a bookshelf or something that is secure and elevates it. Any idea on how high the projector will need to be off the floor? Any idea on what size of picture I can expect? I wasn't really wanting to go for something crazy big but it looks like the projector will need to be closer to accomplish this.
post #2 of 3
You need to decide what size screen you want and then find what projector will do it.
post #3 of 3
just looked again your room is not very wide you will need a long throw projector to fill up a 8 foot screen. I have had 7 projectors with a 8 foot screen with the projector 12 to 14 foot from the screen.
