AVS › AVS Forum › A/V Control & Automation › Home Automation › Quick automation questions
post #1 of 8
I have Control4 for my home automation and in the theater have added an Emotiva amp to run my front stage and an EP4000 to power my Danley DTS10 kit. My question is what is the best way to turn these on and off with the home automation. The EP4000 doesnt have any IR controls and turns on and off with a hard switch on the front. The Emotiva may have something else to be able to control it but I was hoping for some help with everyone that has already experienced this.
post #2 of 8
Not familiar with Emotiva. Which model is it? If they have IR or RS232 control, it should work with Control4 (i'm a Crestron programmer not Control4 so I'm going off of Crestron capabilities).
As for the EP4000, if it only has a hard switch that's the only way to power it on and off. Is it a problem if it's on all the time? You could talk to an integrator about doing a custom circuit board/controller to make a small motor flip the switch on and off. That would be very expensive though, much more than just leaving it on all the time.
post #3 of 8
The Emotiva amp should have a 12v Trigger IN. With this you can power it on and off via C4 IF your C4 controller has an available IO or Relay port. You will want to check with your C4 dealer in regards to adding 12v Trigger control.
As far as the EP4000 goes. You can not remotely turn on or this device using Control4.
Hope that helps.
post #4 of 8
Does the C4 controller have any relays built into it? You could pass the power of the two units through a relay activated switch of some sort...or use C4's switched lamp/lighting (outlet adapter with remote on/off ability) solution?
post #5 of 8
I would be leary of using C4's switched lamp/lighting outlet adapter. If you do make sure it can handle the 15 Amps the EP4000 requires. I don't think C4's outlet adapter can handle that.
With that said, no matter what your C4 dealer tells you, make sure you check with an electrician to see if the C4 outlet adapter can handle the draw of the EP4000 or the Emotiva.
post #6 of 8
Yeah, that was not a well thought-out suggestion, was just thinking about turning a device on and off without considering we're talking about an amplifier...
post #7 of 8
What about power strips that have advanced controls? If the power strip senses current through outlet A then it will activate outlets B-E, or something like that. I think several manufacturers offer them.
post #8 of 8
Thank you all for your replies.
I think I have narrowed down the Emotiva to the 12v trigger and the EP4000 to plug into the Monster cable power conditioner. It looks like I can remote switch certain plugs on and off and it looks like it is also a 12v trigger.
I have never used 12v triggers myself but am assuming I can just use the ones coming from my receiver to these and it will power them up. Any suggestions for me to proceed?
Thanks again
  Back to Forum: Home Automation
