I have been reading this thread for quite sometime. I am trying to work out a video distribution at a reasonable cost. I have tested two HDMI over CatX adaptors with my longest run. Here are my results:
Source-end: Appletv
- CatX Adapter: MonoPrice HDMI extender #6532
- CatX Cables: 117' Dual Cat6 STP Stranded (self terminated)
- Far-end: Olevia HDTV
- Resolution(s) tested: 720P
- Status: Brief Test, no problems
Source-end: SageTV HD-200
- Far-end: same
- Resolution(s) tested: 1080i60
- Status: Did not work
Source-end: AppleTV
- CatX Adapter:
Conversions Technology CT60S
- CatX Cables: 117' Cat6 STP Stranded and Cat5e (self terminated)
- Far-end: same
- Resolution(s) tested: 720p
- Status: Worked but the picture had sparkles/noise.
Source-end: Sagetv HD-200
- CatX Adapter: Conversions Technology CT60S
- Far-end: same
I am not sure why the HD-200 won't work. The HD-200 with the monoprice adaptor would not produce a picture when completely booted up. I saw the "Sagetv" logo when it was booting but this is all. The TV either stated "invalid format or "no signal". The appletv had perfect audio and video for the short time I got to test it.
After reading the reviews on Amazon of the "Conversions Technology CT60S", I was pretty excited and thought it would solve my issues with the HD-200. The HD-200 did produce some color on the screen but other than that nothing was ledgible. I am not sure if I need to use the Rapid Run voltage inserter to make the HD-200 work with an extender or what. the HD-200 is HDMI 1.2 so I am not sure if this would affect this type of setup. I was very disappointed with the performance of the "Conversions Technology CT60S" on the appletv. There was white sparkles in the picture. I switched it between Cat6 cables (I had pulled 2 cat6 cables and 1 Cat5e cable). Neither of the cables appeared to make a difference. I switched to the cat5 cable and things just got worse.
Overall the monoprice adaptor was the clear winner in this short experiment.
