AVS › AVS Forum › Other Areas of Interest › What's Your System Configuration › Condo HT/Music/Gaming Setup
post #1 of 31
Nothing too crazy, but it certainly gets the job done for me! Promised the Mrs. that I'd keep it as minimalistic and unimposing as possible. Would love to hear your thoughts...
Display
Pioneer Kuro 6020FD
Receiver/Amp
Integra DTR-70.1
Speakers
Left/Right: B&W CM-5
Center: B&W CMC-2
Surround L/R: B&W FPM-2
Subwoofer
Velodyne DEQ-10R
Components
All placed in a dedicated media cabinet in the master bedroom closet.
60GB PS3
XBOX360
Wii
Comcast Motorola HD-DVR
HTPC
- Custom built. Running XBMC on Win7 64bit
- Custom built 8TB media server running Windows Home Server. Over 500GB of albums archived in FLAC.
Remote
Logitech Harmony 890
Pics
Fronts (Grills On)
Fronts (Grills Off)
Fronts (Close Up)
CM-5
CMC-2
Rears
Rears (Close Up)
Media Cabinet
post #2 of 31
I'm thinking about doing something similar to this in my new house so I have a few questions.
How do you deal with your Wii in the media cabinet? Do you just have to go there manually and turn it on/off? What product did you use to "forward" the IR commands to the different components
And GREAT setup by the way :-) Looks very sleek and nice
post #3 of 31
Where is the cabinet? How do you route your wires?
Very nice stuff sir.
post #4 of 31
The Wii uses bluetooth, no? I don't need to point wii-mote at the console to turn it on...just press the power button...try it sometime...go into the next room and turn it on from the wii-mote...
post #5 of 31
Wii controllers are Bluetooth, so a press of the power button on one of the Wiimotes powers up the Wii. Same for off. PS3 - same, Bluetooth. XBOX360 - RF, but same principle applies.
As for the control of the components, it's all RF via the Logitech Harmony 890 and RF base stations. Pretty much any RF capable remote will help you achieve the same.
post #6 of 31
Wires are run over the divider wall that the TV is mounted on, into the adjacent wall, and into the master closet, where I had a custom media cabinet installed. Will try to take some additional pics when I get home today.
post #7 of 31
Would you do the speakers again? I'm big B&W fan but I've only heard big ones.
post #8 of 31
Nice looking setup, great job!
Have you tried pulling the CM5s forward just a few inches? If they were near the end of your unit along with the center channel, I bet you would get more depth in your soundstage...I know it may be a WAF thing though...
Enjoy your setup!
post #9 of 31
To be completely honest, the CM-5s were a compromise, as the speakers that I really fell in love with in my price range were the CM-9s. Unfortunately, part of the deal with the wife was no floor-standing speakers in this space. So I went with the CM-5s to leave an upgrade path open in the future (CM-9s up front and CM-5s delegated to surround duty).
Now, I'm no audiophile, but with that said, I've been really pleased with the performance of the CM-5s! They produce a much more full sound than I ever would have expected from a speaker that size. And the FPM-2s are doing great on surround duty.
Overall, I'm really happy.
post #10 of 31
Great looking system. I'm kind of wary about the consoles being in there considering how hot they get, but if it works for you, that's cool
post #11 of 31
Enjoy your setup!
Hey, thanks! The compliment means a lot coming from someone with a system like yours!
And thanks for the tip - will definitely try what you suggested and bring the L/R forward a few inches.
post #12 of 31
Heat was a huge issue for me when deciding where to put all the components (especially with Integra/Onkyo's reputation for hot AVRs). The only thing in the cabinet that's on 24/7 is the server. The remainder of the components are on only intermittently. Also, the cabinet is rear and top vented, and I generally leave the one door open on each side for more airflow. Thankfully, so far, heat hasn't been an issue.
post #13 of 31
Nice system! Very clean and modern looking.
I'm most curious to the specs of your HTPC. I also use XBMC, but on Win XP though I plan to upgrade to Win7 64 once I get a 5 Series Radeon for HD Audio capabilities.
What Skin are you using?
What motherboard/CPU are you using?
Do you have a seperate Video card and which one? or are you using onboard?
Do you have many blurays ripped and how are you going about it? (in folder structure? .iso? .mkv?)
post #14 of 31
Looks fantastic Minazaki! Very tastefully done. The B&W CM series look right at home in your modern dwelling.
Do get to display your speakers naked often? They look best that way I think.
post #15 of 31
Skin: Cirrus
System Specs:
- ZOTAC IONITX-A-U Atom 330 1.6GHz Dual-Core with ION NVIDIA onboard
- 2GB DDR2
Media server is an Atom, ITX form factor. I love the small footprint and low consumption. Runs WHS like a charm. For HDDs I have 4x2TB. Of the 8TB, about 2TB BluRay and DVD Rips, 1TB of TV shows (downloaded/ripped), and about 500GB of albums archived in FLAC.
Regarding BluRay rips, there's probably better people than me to ask regarding the current best methods. Personally, my format of choice for BluRay rips is mkvs with lossless audio tracks converted to FLAC.
post #16 of 31
I agree - naked is way better. Unfortunately, there's already been a small mishap with the CMC-2 tweeter. Diaphragm got pushed in by a guest. The local dealer where I bought them got me a replacement tweeter for $75 shipped. Needless to say, the speakers now get "dressed up" whenever we have company.
post #17 of 31
I don't know what it is about tweeters, they just seem to be finger magnets.
At least the replacement cost was reasonable.
post #18 of 31
UUUUUGH !!! You musta been piiiissssed!! I just got a replacement tweeter for one of my energy's for $40 shipped...loose connection inside housing I believe...
post #19 of 31
That looks like the perfect condo setup to me. Thanks for sharing!
post #20 of 31
Very clean, very stylish, I like it a lot.
lol it's funny that people just can't seem to not touch speaker diaphragms. What is it about them that makes people act like they're 2 years old and just have to touch it?
post #21 of 31
Very nice system. I don't understand women. The CM5 on stands are not taking up any less space than the CM9 would.
post #22 of 31
The footprint is pretty much the same, but visually a floorstander still occupies more territory. There is more air around a standmount.
post #23 of 31
Believe me, I'm aware that the footprint is identical. But I'm not complaining...it gives me an upgrade to look forward to!
btf1980, how long have you had your CM9/1s? How do you like them?
post #24 of 31
Hey, thanks! Glad you like it!
post #25 of 31
I've had a CM based system for the last 3 years, starting with the CM7, and later upgrading to the CM9. I think they offer a tremendous value for their price point. I love the series. The CM9 is a great speaker for $3K. Prior to the CM series, I was a 2 channel guy. Had B&W 805s.
Odd thing, I'm reverting back to 2 channel. Sold my CM1 and CMC2 center channel. I'm a music guy at heart. I can live with watching movies in stereo. I'm sticking with the CM9 for now, but I would not rule out moving up to the new 800 diamond series in the near future.
I think all the upgrading from hifisponge is contagious!
post #26 of 31
Hey bt -
Yes, I'm a bad influence, but you know I can only unlock what was already waiting inside you.
So why sell the center and surrounds? Will the cash recouped go to something else for your stereo-only listening?
post #27 of 31
Hey bt -
Yes. Getting rid of the multichannel amp too. I'll put the money towards a stereo amp. Classe or McIntosh. I just have to demo Pass Labs to reach a final decision.
Sorry for the slight derail OP.
post #28 of 31
I haven't heard the Pass myself, but I have yet to find anyone that didn't consider those amps to be among the best, or even THE BEST they have heard. I guess there is something special about their sound. Good luck!
post #29 of 31
Ha! Are you kidding, I'm relatively new to all of this. Love the discussion, trying to learn whatever I can pick up.
By the way, if you did ever decide to part with your CM9s (and, if only they were piano black), I know of the perfect home where they'd fit right in... with the exception of the occasional curious guest pushing the tweeter diaphragm like a power button, of course.
post #30 of 31
I think I will upgrade eventually to the new 800 series. It's just a matter of time. For my room size, the 804D would be an ideal floorstander.
