AVS › AVS Forum › Display Devices › 2.35:1 Constant Image Height Chat › Best "zoomer" for less than 10k?
post #1 of 18
I thought i would start a thread on people trying to setup a "poor man for now" 2.35 setup. Some of us may be happy with just zooming. And for some it might just be a "stage" until they can afford a anamorphic lens. So this is dedicated to the pjs that best fit this category. Whether its lcd, lcos, or dlp. Maybe we can find a winner in each category. I know that panny4000s and jvcs are very popular with this setup, but what about other's out there? It can be manual or automated setups, doesnt matter. And as far as the price, it should fall under what the pjs are worth today.
post #2 of 18
I first clicked on this post because it was titled "Best "zoomer" for greater than ten thousand". Ten thousand dollars? Is that correct? I have a feeling you mean less than...
Either way, I am interested in seeing what ppl recommend for this setup though
post #3 of 18
my bad....fixed!
post #4 of 18
How about the HC6800 Mitsubishi?
I assume most zoomers would favor motorized zoom, shift and focus?
There should be more models with motorization to make it easier.
post #5 of 18
Having just recently upgraded to a 2.35 screen and using my old RS1, I will say my next projector MUST have motorized zoom, focus and shift considering I am using the zoom method as well and I dont plan on buying a lense since I doubt it would offer much benefit in my paticular setup/seating distance. Having to do all this manually going between ARs is a bit of a PITA so a fully motorized lens (I am thinking RS15 at this point once a deal comes along) is a must in my mind.
post #6 of 18
I'm "zooming" using a new JVC RS25/950, w/motorized focus/zoom/shift. An anamorphic lens is in my future, but zooming certainly will get me by until then. I've built in a macro/vbscript that repositions the lens to/from 2.35 format using the JVC's built-in alignment grid. It's not perfect, as the JVC has no lens position memories/presets. The script sends a fixed number of repetitive up/down commands in the zoom and shift modes until the grid is aligned to the screen. I haven't yet fine tuned the no. of commands to send and I'm not convinced that the JVC will respond the same way every time. But hey, its cheaper than the a-lens.
post #7 of 18
Frankly, with a $10k budget you're better off getting a lens and a projector, you can get a very nice one of each for that budget.
post #8 of 18
The day I spend 10,000 on a PJ is the day someone comes out with a 1080P 2000 lumens PJ with Laser Light engine, 500,000:1 contrast, built in motorised anamorphic lens and utilising the Dolby 3D system. Who am I kidding! I'd still wait till it was eligable for the <$3000 forum
post #9 of 18
any runco ls 3,5 have any experience with this? Or samsung users?
post #10 of 18
The Runco/Planar has manual (hand on ring) zoom and focus, and lens shift requires a tool. Works great with a lens though. Has all the basic aspect ratio modes needed, and an extra one or two.
post #11 of 18
The Viewsonic Pro8100 has motorized everything, perfect for zooming. If you can find one without the dreaded horizontal banding it's a screaming deal at a little over a grand. Next up would have to be the Panny, born for zooming, fully automatic. Better blacks, smoother pans with their fancy creative circuit, a little under 2 grand. Once your budget goes much beyond that it no longer seems to qualify for "poor mans", and you may want to consider a lens.
post #12 of 18
I wonder if there will be a panasonic 5000?
post #13 of 18
Of course there will be... there is always a need for new and creative ways to separate us from your wallets!
...Glenn
post #14 of 18
I hope more pjs come out with a zoom option on the remote control. The panny 4000 seems to be quick and easy
post #15 of 18
Pretty much anything with enough range can do this. Of course for ease of use, motorized lenses (even without memory) are the easiest.
post #16 of 18
I wish there was a list of which pjs could put out a quality image 10 feet wide on a 2.35. It's kind of confusing to me (noob)
post #17 of 18
The new Epsons will supposedly have lens memory and LCOS - think of at as a JVC HD550 (RS15) with dynamic iris and lens memory.
post #18 of 18
Agreed on my end.
