There are a couple of LX900 related discussions spread across the various 2010 Bravia threads. With the 'other 2010 XBR' gathering most of the attention, let's put LX900 praise, reviews, gripes, observations, calibration settings, etc in a thread here.
I just received my XBR-60LX900, replacing a 55HX701 I had for 4 months. The sticker says it was manufactured August 2010.
My LX is in a room with lots of natural light. I have a few observations I can make already compared to some of the other 2010 Bravia models.
Obligatory view of the box (it's big because the 60LX comes shipped with the stand attached)
Out of the box settings with DTV
Side View
Cable Management
Daytime reflections in a brightly lit room with multiple windows
First Impressions
1. Reflections are tamed a bit compared to the 55HX701 but certainly still easily seen (see pictures)
2. Off axis viewing is quite a bit worse than the 55HX701 and very similar to ex700
3. The stand doesn't swivel
4. Out of the box it looks decent with some tendency to get a green tint in certain shadowy scenes and also slightly bluish blacks
5. 2D -> 3D upconversion gives an effect of some sort, but it's hard to really call it 3D.
6. The cable management system allows you to easily route your cables so they fall as a single bundle directly behind the stand, hidden from view in the front.
7. The back of the TV is hi-gloss black plastic like the NX8 series. I haven't heard any of the familiar creaking and popping from the EX700.
8. The widget interface is too slow for my patience.
9. There is some obvious clouding / flashlighting evident on dark scenes and especially on an all black field. This is a bit disappointing for a panel sold at this price point.
Reviews
http://www.hometheater.com/content/s...00-3d-lcd-hdtv
http://www.televisioninfo.com/conten...eview-1741.htm
http://www.televisioninfo.com/conten...eview-1470.htm
http://reviews.cnet.com/flat-panel-t...-33943221.html
http://reviews.lcdtvbuyingguide.com/...br52lx900.html
Technical Info
Panel: 60" - LK600D3LA6N (Sharp)
Input Lag: 50ms
Behind the Cover: KDL40LX900
LX900 related Threads
http://www.avsforum.com/avs-vb/showthread.php?t=1234925
http://www.avsforum.com/avs-vb/showthread.php?t=1267522
http://www.avsforum.com/avs-vb/showthread.php?t=1238342
http://www.avsforum.com/avs-vb/showt...php?p=18866741
http://www.avsforum.com/avs-vb/showthread.php?t=1234877
http://www.avsforum.com/avs-vb/showthread.php?t=1266925
http://www.avsforum.com/avs-vb/showt...php?p=18886612
http://www.avsforum.com/avs-vb/showt...php?p=19098475
http://www.avsforum.com/avs-vb/showthread.php?t=1208677
Side View
Cable Management
First Impressions
Reviews
Technical Info
Input Lag: 50ms
