Originally Posted by
brooks2
Thanks for the reply LBJ2. One question......when the coputer is connected properly does an arrow appear by the device name automatically ?? Now there is no arrow by "PC" and I cannot stop the curser at that item. Thanks again
Hello: I connected my mac with an HDMI cable and saw the arrow in the respective HDMI port. I also dug out an old Toshiba laptop running XP and connected that to the LX900's PC input ( first time I've tried with a windows Laptop with this TV) and the arrow appeared next to the PC Input as well. Once I changed the TV input to PC and selected fn and f5 keys on the laptop, the laptop screen appeared on the TV as expected.
How are you connecting the PC to the TV HDMI or VGA? I ask because if you are using a VGA cable I used a new
Dell VGA PC CRT LCD TV Monitor Male-Male Video Mini D-SUB RGB 15-Pin cable ( these run about $5-$10) to connect the XP laptop to the TV. Since this cable is specifically designed to be used between a PC and an LCD TV maybe that would help you as well?
Also, are you sure your PC's graphics/video card is LCD TV ( digital connection) capable?
