AVS › AVS Forum › Display Devices › CRT Projectors › Been away for 5 years - Need Advice for Marquee 9500
post #1 of 25
Hello All - so I have been away from the whole Home Theater world for just over 5 years. Long story but I sold my house with my theater and I promised my wife I would renovate the kitchen and pool in the new house - 5 years later the kitchen and pool are finally done (and a few other things as well).
About a year ago I started working on the new theater and basic construction is finally done, now time to wire and consider any equipment upgrades.
Here is what I currently have: (1) SDI modded DVD-Player; (2) Key Digital HD-Leeza; (3) 5 BNC cable; (4) 9500LC (actually a Vidikron Vision 1).
Now of course I want to connect a Blu-Ray player to the PJ. What is the best way to do this? Is the HD Leeza now a dinosaur? Should I consider something else?
Any help to get me back up to speed would be greatly appreciated.
post #2 of 25
Hi Dertah, I would first off hook up the 9500LC to a PC and make sure its working properly before anything else. Check to make sure all geometry functions are working etc. a good cleaning of all contacts of boards, daughter boards, removable chips, and wiring harnesses
to and from all boards.
Also while doing this check the LC chambers bellows to make sure they are not sweating or leaking glycol. With the lenses off check the inside of the chamber for any fungus or crud growing inside, if so new glycol will be needed. and possibly new bellows as getting the chamber clean and removing the bellows usually destroys them. This might sound like I am trying to promote my bellows but its nearly impossible to remove them with out tearing them. Also the new material is much less prone to absorbing moisture from the air and wont sweat.
Once you are sure you have the 9500LC in tip top shape i would dump the leeza as it can not input 1080p@24. look into a radiance , curt palme has a special going on right now. If the radiance is too much money they might have some old stock HDQ's. But i have had both and the new radiance is really many steps up in performance.
To get HDMI from the new VP to your marquee get the new Moome VIM-HD card also sold at Curtpalme.com.
Also with look into useing Active area scaning for Blu Ray since most movies are 2.4 aspect.
more reading here on this:
http://archive2.avsforum.com/avs-vb/...d.php?t=737385
Hope this helps
and where are you located so some one near by might offer a hand.
Athanasios
post #3 of 25
before you do anything check those bellows. I have an Accurate 9 here that leaked really badly, luckily it was on the ceiling when it took a dump. Despite that and the owner draining it before shipping I am still mopping up glycol and now suspect a shorted coil on the blue tube.
If you find any wetness around the lenses or mounting plates I would remove all 3 tubes immediately.
post #4 of 25
Thank you both for the advice. To the extent it matters I should clarify. I sold my E-home 8110 with my old house. I picked up the Vidikron Vision 1 (9500LC) from Curt Palme about 2.5 years ago. It has been sitting in my climate controlled basement since then in the crate that it was shipped in.
I will check for leaks as recommended below and clean the contacts.
I am in Connecticut, not far from New York, I would love to hear if there is anyone on the board from my neighborhood.
Another question: should I run the PJ on 220 volts or 110? I am completely re-wiring the entire room and running a 220 line would be easy if there is a reason to do so (my father is a retired electrician).
For signal I will run a 3-inch conduit through the ceiling and start off with a 22AWG HDMI and a 5 BNC cable (my run is about 20 ft.)
post #5 of 25
You should be OK, but yes, check everything they said above. Slightly corroded module connections are common sets that have been sitting, but I should have bled the bellows before I sent the set (I've been doing it for about 4 years once I found out about it), so check for sweating bellows visually), but other than that, fire the set up and see if you get the test patterns before you mount the unit. The test patterns will come up without any input signal.. but you already know that since you've had an 8110.
Run 110 volts, there's no advantage of 220. Figure on about an 8 amp draw at startup, and about 5 amps when running.
post #6 of 25
Hi dertah..welcome back!
I use a DVDO VP30's component side to drive my NEC 10pg. I have a Directv DVR, a HD DVD player and a PS3 providing signal via component to the 10PG via RGBHV and a panasonic RP82 modded for SDI feeding the SDI card in the VP30. I have a HDFury that I have doinked around with off and on and have not been able to make it work (not because of a lack of support from the mfgr, or an unwillingness for others to help...basically my setup works fine now, and I've been lazy.) The VP30 SDI card does not play nice with the HDfury. I want to keep the VP30 in the signal path because of its ability to do gamma adjustment. Also, I really like the PQ from the SDI modded Panny and it's paid for already. Would I go that route starting from scratch? No, but I ain't starting from scratch...nor are you.
If I recall correctly, the Leeza will transcode component to RGBHV? If so, you can do the same thing I do. Run everything via component to the Leeza and out to the PJ via RGBHV. All done.
post #7 of 25
Thanks for all of the advice. I am going to go component to HD Leeza to RGBHV - all while saving money for a moome card and a Radiance! Now I just ahve to figire out what's happened in the audio world.
post #8 of 25
component tot RGB transcoding is tough to do well and your source certainly won't be the cat's meow but for now the important thing is to get the machine ceiling mounted, hooked up, and watching movies.Upgrades and such are easily done down the road as funds allow or you simply get bored with the level of performance from your current set-up.
In Audio the biggest leap has been HDMI fed full studio quality uncompressed audio and 192Khz processing. The biggest bang for the buck out there is the new MAratnz series of receivers SR5004/6004. It's actually audiophile quality sound and power to spare for all 5 or 7 channels. Listened to this extensively at a friends and it blew away Rotel separates.
post #9 of 25
Dertah,
You are going to become seriously constrained with source material if you stay with the HD Leeza. You have a wonderful pj capable of full HD projection and sources that will reproduce fine standard def material. Your problem is going to be getting HD. Without HDMI sources and digital processing, eventually you will only get down rez material. And using HDMI sure cuts down on the mess and expense of the multiple source cables (video and audio) in the rack
I had my 5 BNC cable pulled several years ago and went with Gefen HDMI over CAT5. I've used both the HD Fury and Moome box for conversion to RGBHV at the projector, but the Moome VIM board would be the simplier solution. The Lumagen Radiance doesn't support SDI. The Lumagen HDQ does but doesn't have the wonderful CMS that is in the Radaince. And the Radiance can be used as both your audio and video switch and transcoder.
I have few regrets with 480i over HDMI rather than SDI, there are some nice universal players out there, particularly the Oppos, that get you great sd performance and lets you have HD too.
Good luck!
post #10 of 25
I agree with cooper, the HDQ though does have some CMS, ability to adjust 11 point greyscale and gamma and RGB gamut adjustments. and the ability to get active area scanning and use only the actual scanned area of a BD to your PJ is awesome. run it at 800p@72 hz for 2.4 blu ray and you will be amazed now that your not wasting Bandwidth on the black areas above and below the image.
Athanasios
post #11 of 25
OK so I opened the crate over the weekend and took off the cover. Sure enough there is goo underneath one of the lenses - the green one. It is sitting in a little trough made of aluminum below the lens (the PJ is sitting rightside up).
What should I do? Should I turn it on? Draganm suggested below that I remove all three tubes. Can I do this myself? I would call my skill level intermediate (I did the anamorphic mod on my 8110 but have heard that removing the tubes is a big deal). Is there a guide?
I guess at the very least I need to replace the bellows. I am willing to do what it takes to get it ship shape.
post #12 of 25
Shoot me some pix of the 'goo'. Post here, or email them to me. Let's see whatcha got.
post #13 of 25
Hopefully it did not drip down onto the back plane!!! take off the front cover where the power supplies are. Look into the back , remove the power supplies' to see if any dripped down between them. Also remove the VIM and the CLM at the back of the PJ. Look to the back where they plug in and see if any goo is there. hopefully there is just that small amount.
Athanasios
post #14 of 25
simply unplug all the leads + high voltage wire for each tube. The HV wire twists out CCW. Remove the lenses and the top mounting plate + lead shield. Finally 2 bolts under the lens area hold each tube in. Pull them all out and wipe up and leaked fluid ASAP.
Here's the basic bellow replacement
http://www.curtpalme.com/forum/viewt...=189967#189967
I can do it for you as well, $250. per tube includes new bellows, Glycol, stainless steel fill screws, and return shipping. If the anodize coating has failed add $50. per tube for black Epoxy paint to seal the corroded Alum. housing.
post #15 of 25
OK - I went down to take pictures and there are a few developments. Cracking the seal on the crate must have done something because almost all of the goo is gone from under the Green Tube. Must have evaporated - it was near the little "C" sticker but farther in.
Also (and this can't be good) I noticed a much larger puddle at the rear of the crate on the blue tube side. The bottom of the crate is angled so that the lenses are pointing up on about a 15 degree incline - so all of the stuff appears to have gone to the back. This is the second attached picture.
post #16 of 25
Glycol doesn't evaporate.. ever.. so the goop was something else.
It's time to pull the tubes out and bleed them, and see where the glycol has gone. the tubes come out really easily, so you can see the guts of the set:
http://www.curtpalme.com/Electrohome...e_Layout5.shtm
Bleed the excess pressure out of the tubes via the small hex head screws found on the top metal part of the tube housing. I use a small syringe to suction out some of the glycol so there's a small air bubble under the screws. Don't be alarmed if the glycol comes shooting out when you loosen the screw, that can happen depending on the pressure buildup in the tube.
The bellows may or may not need changing. Some 'seepage' is normal over time, it should be pretty obvious if the bellows are leaking significantly.
post #17 of 25
this is potentially a very bad thing. IF it has "gone to the back" it did so by crawling over the motherboard and back-plane. If so, both should be replaced.
I've even seen that stuff creep down into the power supply bay
post #18 of 25
Id still replace them if the PJ will run and or your willing to have it fixed. the new bellows I had manufactured do not sweat over time as quickly as the 99% silicon original ones do.
Athanasios
post #19 of 25
It looks like you may have gotten to the point where you have to decide how much money you want to invest in this pj. You are already doing it, but find out how much money you are going to have to spend to get it running. After which, you can start to add components like BR player, HDMI device, etc.
post #20 of 25
Athanasios
well the originals seemed to have lasted about 10 years. they're pretty much all shot now and I seem to get daily e-mails from people with leaky Marquee's.
Considering the new Ethelyne-Propelyne material is 90% lower vapor transmission than Silicone it should put the new bellows life-span at approx. 100 years
post #21 of 25
The test they did emulated time as a factor, I forgot how long dale told me the bellows would take to break down and it was long, maybe close to your estimate
Athanasios
post #22 of 25
Look at a 8500 with burned tubes. On local sites etc it can be found for a few bucks. Order new bellows from nashou and you should get it working for less then 500 dollar.
I purchased my ultra chassis for about 125
post #23 of 25
I am going to take it all apart and clean it thoroughly. What do you all suggest for a cleaning agent for the PCBs? Isopropyl alcohol? More importantly, what should I not use?
If I need to replace the Glycol, where can I buy it?
post #24 of 25
I am going to take it all apart and clean it thoroughly. What do you all suggest for a cleaning agent for the PCBs? Isopropyl alcohol? ?
yes, the hardest thing will be getting it out of the socketed connectors if it's crawled in there
MCM electronics, it's called "CRT coolant" at 9 bucks a bottle. you will need 5 of them for 3 tubes
post #25 of 25
This sounds like the perfect advice to me. An 8500 without LC should be immune to the whole problem right?
Make sure it's running good and the port over the repaired and upgraded tubes from the 9500.
You should wind up with some spare parts out of the deal.
I think this is super advice.
Anyways,.. The last 5 years and moreover maybe the last 3 have been significant in terms of progress from other competing tech. CRT is my all time favorite but I use a digital pj now because it's just a lot more practical on many fronts.
I miss CRT though...I think it's the best that was and will be.
=Brian
  Back to Forum: CRT Projectors
