Originally Posted by HiFiFun
Yes but no one will ever tell you:
These players do not have the resources to serve files to other sources especially when playing-back locally. That is why they cost less than a HTPC.
They also do not play back OTA recordings stored by WMC 7. The are great when connected to a 2TB drive chalked full of media files. However these files cannot typically be shared to other rooms.
The Netgear 3700 router does allow sharing of hard drives connected to its USB port. Reads rates are fine for playback but writes are only 3.1MB/sec.
In this way I've "escaped" having a NAS and headaches they bring: power, backups and mandatory reformatting of already full drives to an incompatible windows format.
A small form factor Intel i3 based HTPC with ATI 5750 video card allows me to do anything and everything without constraints. I even have a USB 3 port with Blu-ray 3D playback coming shortly.
Thanks, that puts things in perspective. For my nas type set up, I use unraid which the drives are windows compatibe when pulled from the server.
If you ever go that route again you should look into it.
