AVS › AVS Forum › Other Areas of Interest › Camcorders › Best compressor for .mov ?
post #1 of 7
Is there a better compressor or software program to shrink a .mov video file and still produce a great video image quality? I have seen some video clips from youtube with very nice HD quality and yet it`s a very small file size.
I`m using an iMac right now.
post #2 of 7
I use the Matrox MX02 with max hardware with the accompanying matrox h264 codecs they include. Output is fantastic at all the HD res's (1080 30/i/p, 720 30/60/p), file sizes are small and most importantly, the conversions and transcodes are very quick with the hardware assist. They have conversion settings for compressor specifically for Youtube, Blu-ray, Iphone, Ipad.
If you can afford the unit, it is invaluable. It does a ton of things (HD monitoring, cross converting, capture, hardware assisted acceleration of effects in FCP/Avid/Matrox (in October update)) in addition to the great job it does with h264 compression.
More info here:
http://www.matrox.com/video/en/produ...ily/mxo2_mini/
I don't work for Matrox, but I am a big fan of this unit.
-Alex-
post #3 of 7
Apple's compression software is Compressor, works decently well.
post #4 of 7
Thanks for the response.
I`m using iMovie and when I output my 4 minutes video project in HD 720P, I`m getting around 360MB size. How do I compress this more with less quality deterioration?
post #5 of 7
What codec are you exporting it in?
post #6 of 7
I`m exporting using Quicktime -- apple intermediate codec.
post #7 of 7
YouTube streams 720p at about 2 Mbit/s. I'd say that rendering anything above 5 Mbit/s for uploading to the Web is excessive.
  Back to Forum: Camcorders
