AVS › AVS Forum › Video Components › DVD Players (Standard Def) › Pioneer Laserdisc fix help
Pioneer Laserdisc fix help - Page 2
post #31 of 79
Originally Posted by Kurtis Bahr View Post
For Legato Link you really should go to the 99 or 704 (unpublicized in the 704 but it has Legato Link) to get the D/A circuit to make it worth while. 59, 79 have the cheaper D/A found in the 504 and 605.
Now that's really interesting, and has me curious. Why would the 704 have a better DAC than the (supposedly) upgraded 79? Aren't they essentially the same machine?
Of course, it's really immaterial when you just use the digital out for home theater, but I suppose it might make a difference in a two-channel setup?
post #32 of 79
The common issue with the CLD-504/605/505/605/406/606/59 is that the plastic piece that holds the laser movement motor to the laser pickup breaks and the unit will not play. Usually you gt that replaced and they work. I normally replace them with the one from the DVL series as it can take a bigger shock. Sometimes you just have to unjam the drawer and then they will work. The 79/99/703/704 ship much better.
Your problem is NOT the ribbon cable, you are getting to far into the trying to play cycle for that.
You need to take off the top and watch what it really doing with a disc in it. That will help determine the issue a lot.
Kurtis
Like I said a few posts up, the issue is squarely on the spindle (?) as far as I can tell; it just grinds. It reaches up to connect to the top, but then won't spin. It sounds just like a frozen motor. The laser moves, searches, and everything else it should do. I can't imagine that's the problem.
This thread at least got me this far.
post #33 of 79
The 703/704/79/99 are all essentially the same machine. The 704 lays out the audio board just a little different than the 703 for the AC-3 output but it I do not believe the 703 has Legato Link. Now go to the 79, the main board is laid out differently with the same basic parts as the video board needed to be on top (for the 99 application) and the audio board is on the side but it uses the cheaper D/A parts. The 99 adds the 3D Adaptive filter which is needs to be on top due to required space and the audio parts are changed to the quality used in the 703/704. The mechanical assembly can be directly swapped between these units. Same basic power supply. Visually the same picture.
I still stand by my comment that if you prefer the video output of this series the 704 is the best bang for the buck. The 3D Adaptive Filter is a mid 90's version and any good TV today has a better one. But some people want the Elite look.
My favorite is the CLD-97 for a dual sided player, naturally lower noise having a smoother picture than the newer players but not quite as sharp. The LD-S2 is the lowest noise player if you don't mind single sided.
post #34 of 79
Hey Gang:
I have a D701 and up till now it's played perfectly and the
picture has been...perfect.
Today, when I start playing a laserdisc, the picture while
playing Side A is warbly and haves some waves going across it.
But when Side B plays, the picture is again...perfect.
Any thoughts on cause and fix?
Not a tech-savy gal so...help
Thanks so much.
post #35 of 79
Kurtis...I have a D701 and up till now it's played perfectly and the
Thanks so much.
post #36 of 79
It is possible that side B has always been adjusted better than side A and now the laser is aging so the side not adjusted quite as well has the first signs of issues.
Could be some debris got inside the player to effect the roller that holds the side A tangential angle.
This is usually somehow related to the pickup.
Kurtis
post #37 of 79
Hi everyone. Just tried to start my CLD-D504 and it won't start. Tried several outlets. Anyway, I have two questions. Is it worth it financially to fix it if I'm not good at soldering? And secondly, what is considered the best LD player out there if you were going to look for 2 or 3 that over time have become accepted as being the best?
post #38 of 79
Should have asked the player you had in my other thread. Unplug the unit, take off the top and cut out D106, replace the fuse, then try it again. Will probably work.
post #39 of 79
Hey,
Thanks for the reply. So happy someone wrote back! I have to tell you, I'm not someone who's an expert on LD tech so I have no idea what a D106 is nor do I know what kind of fuse I'd need. If you could help me I'd be very appreciative. I have the manual if that helps.
In the other thread, you mention the CLD-D704. I've got someone near me on craigslist that has the D701. Is that any good? It's $80 and in good condition although people don't usually have any clue how to grade these on craigslist. So, is it comparable to the 704 or totally different machine? And is that a good price?
Also the one I have, as you now know, is the CLD-D504. Was this machine very good? Is it worth it to fix? How much will this fuse cost?
post #40 of 79
So can you (or someone else) explain or send me a link that shows how cut out a D106? And what a D106 is?
post #41 of 79
D106 is an Arc Suppressor, same shape as a diode. Will be near the AC power input. Just take wire cutters and remove it.
post #42 of 79
I have a CLD D406 that randomly give me U1 errors. Its usually if I eject the CD tray and try to play a CD. I can fix it by ejecting the LD portion then gently propping the end of the tray up a little as it moves back in. What do you think might be wrong, and how can I fix it up so that it works all the time.
post #43 of 79
I'm finally going to have some time to give this little fix a shot. In the meantime there's someone near me with a CLD-900 that I might look into. But I'm going to try replacing the fuse in my D504 first.
post #44 of 79
Do you still do laserdisc repair? I have A Pioneer CLD-D702 that is in need for repair, side switch gets jammed and the door does not open with help. When I originally received it from the seller the tray was knock off of the track, also the white platter part that holds the laserdisc in place is missing as a RCA LDR-600 I owned its broke so I salveged the parts from the Pioneer CLD-D702. Also do you still sell players?
post #45 of 79
Yes, I both repair players and sell players. Just not allowed to post for sale ads here.
post #46 of 79
Okay, Thanks.
post #47 of 79
Just wondering but what are your guy's general opinions of the Pioneer CLD-D606 compared to other players like the D702 or CLD-3080
post #48 of 79
i was wondering if anyone ever had a problem with the CLD-505..turned unit on and received an *EO* error..help me please..dont want to tell my dad his gift took a dive..haha
post #49 of 79
Will the drawer open/close. Need more info to help you as there are a few different things to look at.
post #50 of 79
hey all, new to the forum. I have a bit of an issue with my laserdisc player. I have the Pioneer CLD-D504
This was bought brand new from Ken Cranes by my brother. I inherited it and have a library of 30-40 discs. With the advent of DVDs and BluRays, this was tossed in the garage. I plug it in today to my system and it powers on normally. I open the tray and insert Total Recall. The tray retracts, you can hear a drive motor whirring around inside but it doesn't load the menu, it just spits the tray back out. What do you think is the problem?
Pete
post #51 of 79
Being a 504 my guess would be you need to remove the cover and carefully clean the laser lens. Depends on if it was stored in a place when dust gets on surfaces.
post #52 of 79
Can any one tell me what is E3?
post #53 of 79
The laser pickup assembly is either not moving or is in the wrong position. Basically it has a limited time to to trip the LD position switch and it is not happening. Sounds like it needs to be repaired.
post #54 of 79
Hello I seem to be getting 'E3' when pressing eject on my pioneer D515! Any help appreciated smile.gif
post #55 of 79
If you remove the top and watch the laser pickup you will probably find it is not moving. Most common issue is the tabs that hold the movement gears in place broke and cannot properly move the pickup or the motor itself has a bad starting winding. The more common issue is the gears breaking loose and the pickup not properly moving.
post #56 of 79
I have a Theta Digital Data III universal transport (CLD-99). The drawer will open properly, lds and cds seem to load and clamp in place, and the laser seems to move in position. However, once the disc clamps into position, neither cds or lds spin up. Then the drawer reopens. Any suggestions for a try-it-myself fix, or do I need to send it in for repair?
post #57 of 79
If it does not say CD or LD on the display before it opens then it is receiving a reflection off the disc surface. Most likely needs the pickup replaced. I'd say you need to have it repaired.
post #58 of 79
Hi Kurtis,
Would you kindly advise?
I recently bought a cld-a100 (laser active ld player ). The unit played for around a week. Then one day, all of sudden, it stop recognize the disc ld/cd
I replaced the laser pick up with spare (I am sure those spare laser pickup works fine because I tested in the this ld player and took it out and put in box as pare head.
After I replaced the laser head, still same issue.
Here is the action for the ld player when it unable to recognize the disc.
1. The laser head move to the bottom of the disc ( the av output shows play on tv )
2. The laser head does NOT raise up. Motor does NOT spin
3. Then the laser move backward and I do see there.is red beam comes out from the lens.
4. Then the laser head move back to startup position and do nothing
5. There is av output to show stop on the tv
Any idea what is the issue for this? Any suggestion will be really appreciate.
Jimmy
post #59 of 79
Duplicate post
Edited by Jimmy Choi - 1/29/13 at 7:40pm
post #60 of 79
Dup
Edited by Jimmy Choi - 1/29/13 at 7:39pm
  Back to Forum: DVD Players (Standard Def)
