AVS › AVS Forum › Video Components › DVD Players (Standard Def) › Pioneer Laserdisc fix help
Pioneer Laserdisc fix help - Page 3
post #61 of 79
After the drawer closes as soon as the pickup moves to its detection position you should see the lens only move up once trying to get a reflection. If this does not happen with either CD's or LD's then either the ribbon cable that attaches to the logic board is bad or you have a power or electronics issue.
post #62 of 79
Thanks for the reply. The lens does Not move up.
Seems quite hard to find the root cause since it can be caused by many factors.
Do you offer repair service for this model? I am living in Hong Kong, so the shipping is my major concern smile.gif
Thanks again
Jimmy
post #63 of 79
Yes, there are a few of us in the US that work on these players. One is in the state of Washington which would be closer.
post #64 of 79
hey everyone, not to derail any conversations in here, but yesterday I started up one of my CLD-D704's and noticed that is will not display color out of either the composite or S-video connections(I tried them all on 2 different televisions) it just displays black and white. Could this be a laser issue? Also, weird parallel to go with it, but I also noticed that on my receiver, this unit will not output anything but noise through the optical audio connection, whereas the coax still works fine...time to get this thing fixed?
post #65 of 79
My first guess would be a +5V power issue but someone would have to take measurements to verify the issue.
post #66 of 79
just an update on this issue, I opened the unit up and cleaned the spindle etc...and when I started in back up still black and white. But after about 5-6 minutes, even titles that were giving the unit trouble displayed just fine...however a power down cycle later the issue came back, with the same 5 minute interval till color returned...still nothing out of the optical audio out but hissing, but one diagnosis at a time. Anywhere on the board too start measuring? I'd love to break out the multi-meter and see what I could come across.
post #67 of 79
Find a cheap CLD-D503 that works. Swap in the power supply and see if that fixes the problem
post #68 of 79
This is the best help forum I've seen for CLD-99 issues. Hoping mine might have a solution.
I trade favors with a fellow audioholic at work, and he's got a CLD-99 that occasionally locks up with the E3 error after playing an audio CD. When it occurs, the CD plays to the end of the final track, and the laser carriage, instead of parking, immediately withdraws to the back of the unit and jams on the LD tray stabilizer bar. After a couple seconds the carriage motor shuts off and the E3 error displays. If the unit is powered off and the carriage assembly is manually moved forward, the unit will reset and operate normally on next power-on.
Here's the trick: the unit may cycle through dozens of CDs, pressed or burned, without a problem. A blank CD-R won't crash it, and neither will a badly-scratched disc. My coworker took it for service twice and they couldn't replicate it, so it was cleaned and returned without a solution.
I finally found a disc that would crash it about 75% of the time: Fields of Gold, Best of Sting 1984-1994. The only unusual factors are a longer-than-average runtime (1:06:33) and a final track that ends on the minute (5:00).
At first a limit switch seemed like a possible culprit but I can't see one in the carriage path at the time when the failure occurs. Some other sensor? Firmware bug?
post #69 of 79
Gathering the units plays LDs with no problems. When the pickup moves to the back you can see the two micro switches close to the spindle motor that hit the bottom of the pickup. The question would be after playing the CD where is the pickup verses the further away of the two. The closer switch is for CD start position and the second is for LD start position. I have seen this but more on a you power it in and the pickup walks back. I usually end up replacing the pickup and it fixes the problem. But this problem seems a little different.
post #70 of 79
As near as I can tell, neither of those switches is tripped when the failure occurs, but I can double check this weekend by cutting power during a CD playback.
As far as I know, it has never displayed this behavior during LD playback...but OTOH my coworker now mainly uses it as his "benchmark" CD player so it hasn't seen much LD duty in recent years.
post #71 of 79
As it is moving back take a long tool and trip the LD position switch and see it the pickup stops moving back.
post #72 of 79
Well, I ran the unit for half a day and was not able to get a jam, but I did note that when the player is approaching the end of the CD mentioned earlier, the LD start position switch is only partially depressed. Is it possible that the swith is worn and sometimes mis-registers? I'll have to start earlier this weekend and see if I can get the unit good and warm.
Worst case, I might jury rig an external toggle switch in place of the LD position switch and try to force the failure mode manually.
post #73 of 79
Yes they can get worn over time. You can write me at kbahr@comcast.net as I should have some good used ones.
post #74 of 79
Looks like I'll be doing that. Last arrempt , once the unit warmed up, it didn't try to run for the hills on disc end...but did a couple times when I tried o open the drawer immediately after.
post #75 of 79
I know this thread has wandered away from the original D504 issue, but everyone here is so knowledgeable and the thread is seeing replies.. My question is actually regarding a Marantz LV520, but from my understanding is a clone of the D504. I'm not the original owner, eBay purchase for cheap (don't think the owner knew what he had, he thought it was a DVD/LD combi unit).
It had problems initially with skipping or getting stuck every 10 mins or so as well as the U1 error occasionally. I opened it up and lubricated the moving parts. That got rid of the skipping or getting stuck problem which I think was gummed up old lube on the sliding mechanism. Now, when I get it to play, it plays perfectly, included the side change. When it doesn't start correctly it displays"close", CD and LD buttons flash, it makes a whirring noise and then the disc ejects and throws the U1 error. I open and close the tray a couple times, alternating between closing with the LD and play button and eventually get the disc to play.
Any help would be appreciated. I'm just getting into laserdisc, but having a lot of fun. Always looking for a better player though. Thanks for the help in advance.
post #76 of 79
I have not read this entire thread , so this may already have been mentioned , however try this:
The spindle where the LD sits sometimes gets dirty and causes a lot of problems.
I know when I had my CLD-99 , I was pulling the cover off every few months to clean the area where the label comes in contact with the spindle pad.
It`s that rubber disc where the LD sits.
Gary 
post #77 of 79
You need to clean or replace the loading belt. Open the tray and then look inder it at the front left and you'll find the belt.
post #78 of 79
Thanks for the suggestions, I'll try them out. If I have to replace the loading belt, does Pioneer still make the part? If they do, will it work in my Marantz?
post #79 of 79
If this is the issue it is a SCQ4.0 belt you can get anywhere, including eBay.
  Back to Forum: DVD Players (Standard Def)
