AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › JVC DLA-HD250 new entry level DILA
JVC DLA-HD250 new entry level DILA - Page 62
post #1831 of 1857
Originally Posted by Acid Snow View Post
I found one of these on my local CL for $1400, but the bulb is burnt out. ...How much does a new bulb cost?
Edit: Looks like they're ~$280.
List is $399 I think...so its probably closer to that than to $280. Did you actuall saw it listed for that price for a OEM lamp?
post #1832 of 1857
Originally Posted by mariokrt64 View Post
I will try that....the image was so bright, I had to close the aperture, use low lamp, turn down brightness....what you meant by "W"...
Thanks....
Guess it stands for white
post #1833 of 1857
No, I just did a quick Google 'shopping' search, and saw some averages... I then saw the price was higher after posting. $400 sounds more like it.
post #1834 of 1857
That's about what I thougth....original OEM lamps tend to be in the $300-$400 range..It's probably a good profit center for the mfgrs. .I won't buy a generic lamp, though.
post #1835 of 1857
Someone mentioned in another jvc thread about a coupon on the jvc site for about 30% off the list price. Go with the original to be safe.
GL
post #1836 of 1857
GL
do you recall where the coupon was mentioned? link??
post #1837 of 1857
JVCPROMODP1712
from the RS2 thread but someone said it is no longer working off the JVC Pro site.
post #1838 of 1857
Do a Google search on JVC Pro (pro.jvc).
GL
post #1839 of 1857
Could not find it, probably expired.....
post #1840 of 1857
I don't know if its just me...but I kind of feeling the the hrs clock on this PJ is running kind of fast...I have it in normal (low) lamp but it seems to be going to fast...Anybody having or had this experience..Otherwise happy so far with the PJ..much better contrast and image deph..some blurr in NBA games but acceptable.....
post #1841 of 1857
I don't know if its just me...but I kind of feeling the the hrs clock on this PJ is running kind of fast...I have it in normal (low) lamp but it seems to be going to fast...Anybody having or had this experience...
It's easy enough to check
post #1842 of 1857
Well. I know...the issue is if anyone is/had experience a similar situation.....???
post #1843 of 1857
I have a question. It's my first look at more than an entry model projector. The hd250 is lower in lumen compare to a lot of entry projector. Should I ignore this. Also interested in your opinion between this and the w7000, ignoring the 3d.
post #1844 of 1857
The bigger the screen, the more lumens you need.
So, screen size and gain, what content you watch mostly (sports, gaming, movies?), ambient light, etc.
Then there is personal taste. Do you prefer your movies to look like they do in a commercial theater? Or like on a tv/plasma (very bright)??
The W7000 is gonna be brighter for sure, but it's contrast and blacks will also be way worse vs the HD250. An issue for movies, but not so much for sports.
post #1845 of 1857
Also keep in mind that while JVCs spec lower for max lumens than many entry level projectors, they spec higher for lumens at the best calibrated setting - which is what you want to be using for movie watching (perhaps not as critical for sports, gaming).
post #1846 of 1857
post #1847 of 1857
By all means, ignore all publsihed specs, especailly frommost other manufacturers. A new JVC HD250 is extremely bright when combined with the Da-lite HP screen; actually would need a filter. For something like the RS20 which is less bright, my eyes are OK with it. My screen is 106" and sitting about 15 ft away while the pj is about 2 ft in front of me on a coffee table.
I'm sensitive to RBE so would not know how the w7000 is.
GL
post #1848 of 1857
Forgive me if this has been answered, but does the HD250d do 1080P at true multiples of the original frame rate? Anyone know how the picture quality compares to the Epson 6500UB?
post #1849 of 1857
Projector Reviews does a good job and they have reviewed both of these.
Here is a link to the 6500UB competitors area. Scroll down to see what it says about it vs RS1/2 which are similar to HD250, but the HD250 is a newer model from JVC.
http://www.projectorreviews.com/epson/home-cinema-6500ub/competitors.php
6500UB review
http://www.projectorreviews.com/epson/home-cinema-6500ub/index.php
HD250 review
http://www.projectorreviews.com/jvc/dla-hd250/index.php
Epson is better for viewing in ambient light situations, the JVC better for light controlled situation... What are your typical viewing conditions?
post #1850 of 1857
If you are viewing in best mode in terms of brightness, 250 wins all the way. I had both the JVC and an Epson 8500. The 250 was a considerable upgrade from the 8500 IMO.
And you don't have to worry about dust blobs with the JVC!
post #1851 of 1857
Is the HD250 a big step up from a Sony VPL-HW15?
Is it worth the switch?
post #1852 of 1857
avs has b stock due in any day fyi... I just ordered myself one
post #1853 of 1857
Price?
post #1854 of 1857
I'm thinking of the B Stock, but don't know if it is a worthwhile upgrade from my current VPL-HW15.
Otherwise, I shoudl sell my HW15 and move to the X30.
post #1855 of 1857
Just got my b stock of this receiver from Avs today. I thought my previous mount I used with my optoma would work but its nowhere close. Can anyone recommend me a good cheap mount or have instructions for building my own? Search isn't helping much unfortunately.
The previous mount I had is about 12inches from the ceiling but my last projector didn't have any lense shift
post #1856 of 1857
yonexsp,
I moved from a HW15 to the RS10/HD350 (other than chassis, same as HD250), no contest in terms of brightness, sharpness and contrast. The Sony is quieter and the color a bit more natural (personal taste).
GL.
post #1857 of 1857
I have the opportunity to purchase a refurb JVC250 for $1399 or a preowned 8700ub with only 73 hours on it for $1000. I watch only in a completely dark TREATED room and only movies on Bluray. 100-110" screen. Which projector would be the better one?
