Any comments on the 12v trigger? (Last page)
post #481 of 1857
10/21/10 at 10:19am
) should be mounted so that the center of the lens is at about the horizontal center of your screen. That way, only very small amount of horizontal lens shift will be needed to "tweak" the horizontal alignment. this leaves the majority of vertical lens shift available for use (that's what is really needed for most installations, anyway).
maybe it will help u find some. I'm torn between the carada and the Stewart studiotek 130! Carada is 1000 with a real world gain of 1-1.1. The Stewart is more than I paid for the projector. I'm projecting a 139" screen at 14ft 4in away. Myroom is totally light controlled I'm painting ceiling black tonight! I guess I'd like to keep the extra 1600 in the bank if possible! However I made a mistake buying epson 8100 and ended upgrading in less than a week.
