AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "Official" Denon AVR-4311CI/AVR-A100 thread [NO PRICE TALK]
The "Official" Denon AVR-4311CI/AVR-A100 thread [NO PRICE TALK] - Page 505
post #15121 of 21942
Originally Posted by mcsoul View Post
I've found newegg reliable, I've just had to pay for shipping if I want to make returns. In this instance you CANNOT return it for cash, just another unit and only if you find the defect fast. You just need to go in wit the proper expectation. If you apply for their 12m zero interest, you become a "premier customer" if you are accepted. That may help too.
I too, newegg is one of the best.. But in this case, there just a drop shipper.. If all is good, if there no problem, if there is a problem, then the B&M is the best.. If you have a problem there is nothing thats beats the face to face at a b&m store for results....Unless your a real wimp..
post #15122 of 21942
Originally Posted by JerryW View Post
And if anyone is to "blame" here it is denon for not policing their authorized dealers - they are certainly capable of tracing serial numbers back to find which authorized dealer dumped the product on grey market in the first place and punishing them by revoking their authorized dealer status.
AFAIK, Denon has already revoked the "authorized" reseller's status that Newegg purchased their units from.
post #15123 of 21942
Was able to buy one from electronics expo at just a tad over neweggs sale price today. They are an eithorized dealer.
post #15124 of 21942
Don't leave us hanging like that. Who was it?
post #15125 of 21942
Hey Guys! I just picked up a 4311ci and the Airplay update. I am having a weird issue, and I am wondering if this is the limitation of adding the airplay update, or if something is wrong with my receiver. Here is what is going on:
When I go into Net/USB, I get NO OSD on the TV, not even a little, none. The only display is on the front of the receiver. I even tried running a Flickr photo stream and it shows one is running on the front of the receiver, but I get nothing on the display. Any ideas?
I also get no OSD when I am browsing Internet Radio menus.
I did a full reset on the microprocessor to no avail.
Help please
Don
post #15126 of 21942
Help! My new 4311 arrived today. I just finished the setup and the right surround volume is very low. If I move it to other speaker post it sounds fine. Place another speaker in the right surround post and it is low.
I have reset the microprocessor and reset the settings. Any ideas??
post #15127 of 21942
Weird...it is ok now... Ghosts?? Warm-up??
post #15128 of 21942
I'm not privy as to the "who", rather only to the action taken.
post #15129 of 21942
I'm no lawyer but my understanding is that a manufacturer can't deny reasonable warranty service solely based on where the customer purchased the product for some definition of "reasonable" that has been left up to the courts to determine.
Your understanding is incorrect. Manufacturers absolutely positively can deny warranty service for products purchased from unauthorized dealers.
In some cases, the situation is even worse. For example, Sumiko Audio, the U.S. distributor for brands such as Sonus Faber, REL, and Wadia, won't even let you buy replacement parts unless you can show proof that you purchased the original product from an authorized dealer in the U.S.
post #15130 of 21942
Seems like you have a bad amplifier channel. I sugggest you contact the dealer and request a replacement for the 4311.
post #15131 of 21942
Any thoughts on adding an amp to my three week old 4311? Thinking about an Oulaw 7125 (7 channels - 125 watts). Eventually but not soon I would like to add heights or wides. The receiver is driving Sierra Ascends across the front - 7.1 setup. No plans to give up the Sierras. Continue to be impressed with this receiver and XT32. It seems like a number of you use an amp with the receiver - Thanks.
post #15132 of 21942
Originally Posted by AustinJerry View Post
Exactly what I use, an Emotiva XPA-3 driving LCR.
That's actually the set up I was considering. My only concern is speaker output at different volume settings. Is audessy able to compensate for 3 channels having higher power...or do you run audessy at a certain volume setting and if you listen at anything different (higher or lower) the 3 fronts will not have the correct level setting as the other 8 channels.
post #15133 of 21942
Assuming you re-run the Audyssey calibration after you hook up the external amplifier, the levels for all speakers will be set correctly. The balance among the speakers will not change at different volume settings because of the external amp.
post #15134 of 21942
Help please
Don
Please help! Can anyone confirm this? I need to report back to the seller if something is wrong.
Thanks everyone!
Don
post #15135 of 21942
Originally Posted by smurraybhm View Post
Any thoughts on adding an amp to my three week old 4311? Thinking about an Oulaw 7125 (7 channels - 125 watts). Eventually but not soon I would like to add heights or wides. The receiver is driving Sierra Ascends across the front - 7.1 setup...
It sounds like you don't need two extra channels so are considering external amplification for another reason. So what is that? Many folks consider the internal amps to be quite good irt SQ and quite capable irt SPL for most rooms and gear and don't buy into the idea that an external amp is likely to improve SQ or dynamics. I bought my Emo XPA5 to help a Denon 4310 drive my 7.2 system with 4 Ohm Dalis as I could hear decreased SQ/dynamics when I cranked it way up (the 4310 was only rated down to 6 ohms, the 4311 is rated to 4). Do you hear a problem like that?
As to possible pros of spending $ on an Outlaw, relevant factors include the sensitivity and ohmage of your speakers, how far you are from the speakers, how acoustically "dead"/absorbant is your room and how loud you listen.
post #15136 of 21942
Accessories4less has a good deal on a Sherwood R-972 for those still considering absolute performance or price-based performance.
post #15137 of 21942
Well after finishing the config and shutdown last night...that channel does not play again this morning. It looks like I received a defective unit. Thanks for the response.
post #15138 of 21942
Help please
Don
I have the same thing on my 4311 and so far none of the sugestions from several members have helped. Hope we find a solution.
Rod
post #15139 of 21942
Rod
Not good. So does it work correctly for other people? If so, I will be returning this unit as not as advertised to the seller. Has anyone else confirmed that it does work for them? If so, I will just be replacing it. I just am looking to know if this is normal, or a bug/defect.
Don
post #15140 of 21942
Thanks everyone!
Don
Well my unit has a bad channel, but I get the OSD after the airplay update. Volume change as well as a nice GUI that shows me the artist, cover art etc.
There is a setting under manual setup, Option Setup, GUI, Net/USB: make sure that the setting is not turned off
post #15141 of 21942
The GUI option is set to always. If I set the background to blue, I can see the blue background, but no other information is displayed. Ideas? Does it sound like I have a defective unit?
Don
post #15142 of 21942
I mentioned this before, but Flickr doesn't display any images either.
Don
post #15143 of 21942
Don
Don,
I am new to Denon and a bit disappointed today given my first is a DOA. I cannot recreate your issue other than by turning off the GUI for NET/USB. I would guess that would also affect Flicker. Believe me, I don' want to pack this beast up and wait 2 weeks to get the replacement either, but I think that is where we are. There are some amazing folks on this forum. If they have suggestions, I know they would give them. I would contact the seller if I were you.
post #15144 of 21942
I'm locked out of using the remote.
When I try the display states " Remote lock: on"
Nothing in the manual or online about this that I can find.
Looks like I must have disable the remote, now if I can only find out how to re enable.
Torben
post #15145 of 21942
My wonderful2809ci had a switched ac outlet. My new 4311ci which I am about to get lacks this but has trigger outs. What is the cheapest way to turn these into a triggered AC? Thanks
post #15146 of 21942
Don
Just a guess, but do you have Video convert" set to off? If so, that may be the cause of both the OSD and Flickr display issues.
post #15147 of 21942
I double checked that and the i/p is set to Analog, not Off...
Any other ideas?
I have contacted the seller and I am going to call Denon the start of this week and we will see what they have to say. If they don't have any ideas, it looks like I am going to send it back.
Don
post #15148 of 21942
Any other ideas?
Don
Change it to analog and hdmi if your display is connected via hdmi. page 83 of the owners manual gives the description of the settings if you want to review the details.
post #15149 of 21942
Not cheap but if you search around for something similiar to THIS on maybe ebay you might find cheaper
post #15150 of 21942
Analog or Off are the only options available since the NET/USB input cannot have an HDMI input assigned to it. At least that is the way I interpreted the manual. Still no luck here....
Don
