Originally Posted by ccotenj
no. it doesn't. if it doesn't clip or shut down, it's as good as it gets.
if you want the 3 ways, go for it... frankly, imo, ANY in ceiling speaker solution isn't going to provide "good sq", no matter how good it is, because positioning a speaker on the ceiling can't do anything other than provide ambient background music...
I think I follow you. But, the 2 in kitchen are single stereo SST ones that pivot and are pointed at the kitchen island. The 3 ways with separate tweeter, mid, and woofer are an upgrade and hoping will be an improvement. Especially when I play older live recordings...
The power amp im using is only 52 watts per channel at 8 ohms, 70 watts per channel at 4 ohms. Maybe with the denon i can ditch that and just use the denon to power zone 2.
I will work on a replacement... Oh and I did try the reset in the manual.
Return to sender.
