Originally Posted by jdsmoothie
By "I reset defaults" do you mean you reset the microprocessor? When you rerun it, it's generally suggested to use all 8 positions rather than just 6, although that shouldn't have any effect on the issue you have. As a test though, I would only run 2 positions and STORE after that just to make sure it works correctly before going for all 8 positions if you have the time.
My room is 12x8 feet... The only way I could do 8 positions is if I just moved the mic 1/2 a foot each time.
I will rerun with 2 positions just to see if it happens again.
