Originally Posted by jdsmoothie
Nope, there's nothing in those 2CH STEREO settings that would negate Audyssey and as has been often noted, Audyssey ignores all settings prior to running the EQ process. To add to what batpig noted, these are just a "subset" of the main zone settings when in "custom" mode.
batpig and jd,
Thanks for your thoughts
.If you change from Basic to Custom or vice versa will it matter as far as retaining the Audyssey calibration?
If Audyssey ignores all settings prior to running the calibration why are you asked to set amp assign and number of speakers before running a calibration? If you change any of these main settings after a calibration then that calibration is negated (which I fully understand why).
Bill
. I did not have these feelings with XT. I will make a call to the SoM 24 hour 4311 hotline as soon as I can find a couch to lay down on
