Originally Posted by pbarach
I hear no difference playing CDs from my DenonLink 3 player (3109) compared to my two BluRay players connected to my 4310 over HDMI or digital coax. In all these cases, you are using the AVR's DAC, so there will be no audible difference on CDs. The DenonLink players do have the advantage over the BluRay players when it comes to SACD or DVD-A, since the signal will go to the AVR digitally and can then be Audyssey-processed before conversion to analog. Any of the Oppo players will do the same thing as the DenonLink players because they can send SACD or DVD-A to the AVR over HDMI.
Hi. Interesting that you don't hear a difference between CAT5DenonLink and HDMI. As always, YMMV, and that may be due to differences in our gear and rooms. As to gear, I never compared DenonLink in the 4310. When I had that AVR I didn't have the DBPA100 (4010). Back then, I did many comparisons of Oppo 83SE analog vs digital connections to the 4310 and established that in my room (no formal acoustic treatments and bad boomy bass problems) any slight SQ advantage in high end detail using the Oppo DACs, Ext In, Direct Mode, etc., for Stereo were not worth it if it meant giving up MultEQXT. Before I had the 4310, I had the AVR 2809 and I'd concluded that using those Oppo DACs offered a slight advantage overall if I used standard analog IN on the AVR and redigitized the signal and applied Audyssey. I know, kinda kooky but that's me.
As I've posted on my "Does DenonLink really matter?" thread, I was skeptical that jitter reduction ( supposedly the advantage of the proprietary DenonLink technology) would make a worthwhile sonic difference. Based on reports, some from folks I consider quite credible, I tried it for myself and posted the results in the DBP4010 thread. The SQ improvement once I got AVR A100 (4311) with XT32 was considerable in several areas including detail, imaging and soundstage. Perhaps that better allows me to hear the difference with DenonLink. Or mebbe I'm just full of it.
Edited by SoundofMind - 6/10/12 at 1:29pm
i hate getting sucked into these discussions...
