post #18001 of 21928
6/13/12 at 9:50am
- batpig
- Trader Feedback: 0
- terrorist and rioter
- offline
- 21,150 Posts. Joined 2/2007
- Select All Posts By This User
HDMI audio is not inherently better than optical (or digital coax) audio. It just allows more bandwidth so you can pass higher resolution formats. So as long as a signal can "legally" pass via optical it will sound exactly the same as passing it via HDMI. With TV signals you are getting at best Dolby Digital 5.1 which passes just fine either way. The only difference would be with higher rez formats (like on a Blu-ray) which can't pass via optical.
(DHCP).
Still there is nothing better to pass by way of ARC then the DD 5.1 so to heckwith it. I figure why fight with it over 1 small cable.
