Thanks Gregavi. I did try resetting the microprocessor a few times but that did not solve the issues. Any other suggestions?
post #19831 of 21934
11/18/12 at 7:58pm
Trouble-shooting is usually a process of elimination.
- There are several HDMI outputs that the TV can be connected to. Try another one.
- Try a different HDMI cable.
- Try a different type of connection to the TV (Component, composite)
- Is the 4311 outputting video at a higher resolution than the TV can accept? Try turning off video conversion in the 4311.
If still no luck, what is the return policy for the open-box unit?
Yes, you will need to run a Network Save. The procedure is described here: http://www.avsforum.com/t/1430049/the-official-denon-avr-4520ci-thread/330#post_22487485.
While the link references the AVR54520, the procedure for the 4311 is the same.
