Originally Posted by jdsmoothie
Can't point to the page as the manual isn't posted on line yet ....
Set HDMI Control to ON (default is OFF and the power ring will glow "red" when the unit is in Standby to indicate HDMI Control is ON) and then set the HDMI Standby Source to either LAST or whatever HDMI jack the source you want to pass is connected to. Also you'll likely have to set the HDMI-CEC in the TV to OFF.
JD,
I will follow your instructions. Also, where is it located in the 4311 manual? I would think the procedure would be the same.
Willie
