AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon & Marantz release official iOS remote control apps
post #1 of 5
Yesterday, D&M Holdings released official iOS remote control apps for Denon xx11CI series & Marantz x005 series networked AVRs & pre/pros.
http://itunes.apple.com/us/app/denon...388608880?mt=8
http://itunes.apple.com/us/app/wizz-...388917986?mt=8
According to a Denon official in the following thread, these apps will also be used to control Denon's iTunes AirPlay implementation.
http://www.remotecentral.com/cgi-bin...read.cgi?22725
AJ
post #2 of 5
No support for other models and does less than the other apps already released on the store. I guess its a start...
Daniel.
post #3 of 5
Daniel.
Danielo, Which other apps are better that support these products?
post #4 of 5
No support for other models...
You got it backward. Your problem is not that the Denon Remote app does not support other (read: older) models; rather, it is that older models do not support the app. The support has to be built into the AVR or pre/pro. And, face it, your AVP is technologically getting a bit long in the tooth.
AJ
post #5 of 5
I previously posted about the third party iOS remote apps, Mobile Safari remote screen (xx10CI series), and other mobile browser remote screen (xx08CI series). See these posts:
http://www.avsforum.com/avs-vb/showp...postcount=1197
http://www.avsforum.com/avs-vb/showp...45&postcount=4
AJ
