I currently have a Polk RM6750 and was looking to upgrade. Definitely in need of some help. Thanks in advance...
My plan is to keep the sub and surrounds(for now) and just upgrade the fronts and center. Here's what I've got:
Room: 14x20
Budget: $500 but can go over if justified(slippery slope)
Receiver: Onkyo 606(90w/channel)
Usage: Home theatre
Need: center and 2 floorstanding fronts
I've been reading these forums quite a bit and identified the following targets but I'm open to others.
Polk Monitor 60 Series II($109 at newegg)
Infinity Primus 362($200, Frys appears sold out at $149)
Polk TSi300($200)
KEF C5
KEF IQ50($300)
Boston Acoustics CS226
I guess I'm one of the ones with the Klipsch sensitivity so I've ruled them out.
Everyone that gets the Polk Monitor series seems quite pleased. I'm a little confused by how they match up against some of the other entry level speakers above. I have a little extra budget beyond them but if they're that good...
Unfortunately, there isn't anywhere to demo most of these speakers in the area.
Thanks again
Room: 14x20
Usage: Home theatre
Polk TSi300($200)
KEF C5
KEF IQ50($300)
Thanks again
When I looked into stands I realized I'd be paying more than the speakers were probably worth. I also dislike the center on RM6750 so replacing that has been on the todo list forever. The Monitor 60 and CS1/2 combo from Newegg would accomplish both of those goals so I've already committed to go at least that far. The question is whether I should put in some more money to go a little higher end...
