AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Problems connecting Sony Blu-ray player to internet
post #1 of 14
Wondering if anybody can help me connect my new Sony Blu-ray player (BDP-BX57) to the internet.
I don't use a wireless network at home. Everything is wired. I bought an ethernet switch (Trendnet 5-port 10/100MBPS Fast Ethernet Switch). I have an ethernet cable (CAT5e) running from the cable modem (from comcast) into the ethernet switch, and an ethernet cable running from the switch to the back of my PC. Internet works fine from PC. Just hooked up the Sony Blu-ray (BDP-BX57) to the ethernet switch with another ethernet cable (CAT5E). The internet still works fine on my PC, but the Bluray player can't connect for some reason.
When I look at the player internet diagnostics, it reads:
Connection Method: Wired
Physical Connection: OK
Internet Access: Failed
etc..., etc...
It shows my IP address and other info, but it can't connect for some reason. Does anybody know if I'm doing anything wrong?
post #2 of 14
Your cable modem will only provide one connection (IP address) to the Internet. You need a "residential gateway" aka 'a router' to allow multiple devices to share that one connection. This would replace the switch (or at least be the first thing after the cable modem, you can use that switch to increase your port count later). This one will do the trick:
http://www.newegg.com/Product/Produc...-091-_-Product
Note, however, that since *wireless* routers are so popular, they can be had for the same price:
http://www.newegg.com/Product/Produc...82E16833127241
Even if you don't need the wireless today, for the same price, get one - and just turn off the wireless network until you need it.
Jeff
post #3 of 14
Thanks a lot, I'll try that!
post #4 of 14
need a little help, already been on the phone with Sony support and they ran out of ideas. they had me reboot the modem, because a diag mentioned a DNS failure, reset to factory settings and tried everything all over again.
I have a cable modem connected to a Linksys/Cisco E3000 wireless router.
My download speeds are sufficient at 11Mbps. I already have a Wii accessing the internet. But i cannot figure out how to get the Sony BX57 to access the Internet.
I get Connection Okay, Internet access Failed.
I can see the Sony Player in my routers client Table.
Tried auto/scan connection, WI-FI protected setup, and a manual connection entering all the addresses.
This router is dual band. I have set the 5ghz band to WPA2 encrytion and verified the keys again and again. still get okay/failed result.
I have even tried disabling the router firewall while trying to connect the player!
still okay connection, failed access!
The router also has an Unencryted guest network that I cannot get this player to access. I know the guest network is good, I can connect to it using the phone.
Still get okay/failed result!
Do you think it could be a faulty player? I am outta ideas... would love to hear if anyone has some suggestions, before I make a trip to return!
post #5 of 14
Probably not a faulty player, but could be a firmware / compatibility issue with either the player or the router. Also, I don't know if the player is using the 5Gz band, probably only the 2.4GHz. Make sure you have the 2.4GHz band enabled (mixed b/g/n). If it can't connect to an unencrypted/open guest network, that's not a good sign... A couple of other things to try:
1) Check for firmware upgrades on both your router and the BD player - make sure you're using the latest. The Sony will have alternate ways to update the firmware if you can't connect to the Internet.
2) Attach the player to the router using a wired Ethernet connection and see if it connects.
3) Attach the player directly to the cable modem (disconnect the router) and try again.
4) Borrow a different make/model of router, or take the BD player to a friend's house any try their setup.
Hope that helps, these types of issues are never easy...
Jeff
post #6 of 14
I have the same problem as described above with my BDP BX57. I can connect to the wireless router, but it says that the gateway is not responding. Funny thing is, that I can get all of the streaming services without a problem. I even get notices displayed on the box from Sony that I need a firmware update. Therefore, it is connecting to the internet just fine. Also standing next to the box, I can get to the internet through my wireless router with my laptop and cell phone.
But when you look at the network status, it says that there is a wireless connection but no internet connection. The Sony Diagnostics say that the gateway is not responding, but I know the gateway is fine, I have three other computers and two cell phones that are going through that gateway without any problems. I checked all of the IP addresses and they are what they should be. Why are they looking for a response from the gateway anyway? Shouldnt they just be passively going through the gateway? Are they trying to do something stupid with my gateway as part of their DRM?
When you try to get a firmware update, it says that there is no internet access so it will not update. I finally downloaded the latest firmware update and put it on a disk and updated the box manually, but it didnt change anything.
I finally hardwired the box to my wired main firewall router to bypass any potential wireless problems, but it didnt fix anything, I still get the same problem. I have 20 Mbps internet connection, so I know that it is not a bandwidth problem. I also checked that cable going to the Sony by connecting it to my laptop and it connected to the internet just fine.
I think that the problem is a software glitch in Sonys communication program. Sony customer service claim that that would be impossible, and thats what convinced me that it was true. All the streaming services connect and play just fine, except Netflix, which keeps loosing connection because Sony is rerouting all Netflix through their overloaded servers, but that is a different known problem with Sony.
If you can ignore that fact that it is only the Sony update service, status screen, and diagnostics that can't connect to the internet (everything non-Sony connects just fine) the machine isnt all that bad.
post #7 of 14
I have FINALLY figured out the solution to the 'gateway is not responding problem'. My firewall box is setup to not respond to ICMP pings. Once I allowed it to respond to pings, everything started working. Apparently, what Sony is doing is a ping to gateway as the first step in evaluating whether or not you can connect to the internet. Netflix, Youtube, and all the other apps couldn't care less and they work just fine. I am now able to perform network updates over Wi-fi, which was actually the main reason I sprung for a Blu-Ray player with Wi-fi in the first place. I hope this helps somebody else out because it took me HOURS to figure out and Sony certainly wasn't any help.
post #8 of 14
Originally Posted by justin6case View Post
Sony is doing is ping to gateway as the first step in evaluating whether or not you can connect to the internet.
Kinda intrusive if u ask me.
post #9 of 14
wow; just turned "ping" on and viola. That is shady. oh well...
post #10 of 14
we deeply regret the problem caused to you. please make a call to our customer support team,they will assist you in this.
Thanks and Regards
Sony Support
post #11 of 14
I seem to be having the same issues trying to connect to actually anything through my blue ray player. It keeps saying "provisional server failed". I've checked my internet and everything is fine. I'm use lynksis 2.4. I was able to connect to the internet yesterday but today I'm getting the "provisional server failed" message. I'm tried disconnecting and reconnecting everything but this doesn't help
post #12 of 14
How did you allow for pings on your firewall box? thanks!
Kristen
post #13 of 14
Yes how do you do the ping thing?! I have a Sony Blu-Ray with WiFi. and haven't been able to get communication going between my router and the Blu-Ray.
Frustrating!
post #14 of 14
Not sure if this will help you but i went into the settings on my sony and turned off auto access permission under renderer options, mine was already hooking up to the wifi but kept bringing down our internet everytime i tried to watch a movie via wifi
  Back to Forum: Home A/V Distribution
