I am on it as of next week.
Had enough with the T__t, still need digital mch out. Don't want to risk sending 12 channels of signal on analog xlr 35 feet and then get noise, there could always be noise with analog, but if you choose a high quality dac right next to the amps like this:
The Prism Sound Dream ADA-8XR converter provides eight channels of high-quality 24-bit, 192kHz A/D AND D/A conversion, allied with a wealth of sophisticated features for the most exacting applications in sound recording, mastering and broadcast. The Prism Sound ADA-8XR is ideal for location recording, stereo and surround mixing, mastering and monitoring, or as a flexible companion for your DAW or MDM. The ADA-8XR takes the philosophy of the widely-acclaimed Prism Sound converter range a stage further: For the first time, the same goals of ultimate sound quality and versatility have been realised in a multi-channel, 192kHz-capable format. Eight channels of high-quality 24-bit, 192kHz, A/D AND D/A conversion (or 16 channels of A/D or D/A) Flexible digital interfacing options: AES3 - 2-speed or 2-wire, also handles S/PDIF FireWire - for direct connection to DAW software on PC or Mac Pro Tools|HD - direct connection of up to 32 inputs and outputs per card Pro Tools|24 MIX - direct connection in place of 888|IO DSD - for SACD production, with SDIF2/3 and optional MAC-DSD (Cat5) interface; also allows sample-rate-conversion between any PCM rates Built-in Prism Sound 'SNS' noise-shapers for ultimate 16-bit and 20-bit reductions Built-in Prism Sound 'MR-X' word-mapping for lossless recording up to 24-bit, 96kHz on standard DA-88 or ADAT MDMs, or other 16 or 20-bit media Built-in Prism Sound 'DRE' function gives 24-bit performance on 16-bit media WITHOUT sacrificing tracks Stereo monitor, with headphones and analogue AND digital line outputs, can monitor any input or output pair, or a panned stereo mix of all eight channels Electronically balanced, transformerless, galvanically isolated XLR analogue inputs and outputs ensure freedom from noise pick-up and crosstalk, with software-controlled balance and line-up Ultimate Prism Sound clock-stability and jitter-rejection for crystal-clear imaging, with independent multiple PLLs for A/D and D/A paths Prism Sound 'Over-killer' selectable on analogue inputs: the best-sounding gentle limiting for louder masters - with no 'overs' Intuitive user interface, provides fast access to all I/O and processing functions; with continuous display of all settings Versatile eight-channel LED bargraph / status monitor can access all points in A/D or D/A signal paths Expandable DSP 'processing' module in each path All signal processing functions can be also be carried out in 'D-D' mode, including conversion between different interface formats Modular construction allows upgrading of all input and output cards (INCLUDING A/D, D/A, and DSP boards); no need to worry about future converter advances or new interface standards Internet-upgradeable software - loads from your PC or Mac into 'flash' memory inside the ADA-8XR
Click To Enlarge
Item #: Prism ADA-8XR Standard PTHD
* Marked fields are required.
Qty*
Price $10,404.00
