As for hardware products our main business model is still to let someone else do the hardware, and focus on what we are good at, i.e. software. A good example of a home space hardware product that is on it's way is the DL2 by Karlton Audio, and of course later also the DL3.
We are however going to release on our own purely software based end-consumer product range directed at "computer audiophiles" where Dirac filters can be generated and then run in real time on a PC or a Mac
Please keep an eye on dirac.se the coming months for announcements, I can also contact you personally should you want me to.
Originally Posted by GGA
I am curious as to how Dirac Live does subwoofer and main speaker time alignment. Because of the large wavelengths this has always seemed to be difficult problem to solve by measuring arrival times. Trial and error seemed to be the rule of the day. Are you able to not only get the two sources in phase, but also to have them time aligned so that the initial wavelength of each source arrives at the same time?
The time alignment between subwoofer and main speaker is indeed a very tricky issue. In the AP20, the alignment is based on estimation of arrival times. The difficulty, just as you point out, is the large wavelength of the subwoofer response which makes it difficult to even speak of a distinct arrival time. Another solution is to time-align them so that the best summation in the cross-over region is achieved. That is, to optimize with respect to the sum response. In the present implementation in the AP20, this is not yet implemented. But who knows, we might be working on something...
Best
/Chris
