AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Dish Network 21.0 Learning Remote
post #1 of 2
You guys have been very helpful to me over the years, so I thought I would try to return the favor. I didn't see this thread anywhere, so I hope I'm not repeating general knowledge.
I recently bought an off-brand LCD (25 inch 1080p Hannspree, great picture) to replace an analog tv. I wanted to use my 21.0 learning remote, but could not find any working codes for Hannspree in the the 21.0 manual. So I ended up using the learning function to teach it from the Hannspree remote. I did not teach it all the buttons, just the ones I thought it would need. At first, it worked great, but like a half an hour later, it would lose everything I taught it. Reprogrammed it several times before I finally figured out the problem. (Dish Network tech support was worthless...on this problem.)
Using the learning function more than once erases the previously learned functions. For example, say I needed to teach the 21.0 remote 12 buttons from the Hannspree remote. If I taught it 10 buttons, then quit, those 10 buttons would work great. No problem. But if I went back in and taught it the 2 buttons I missed, the 10 buttons it already knew would be erased from its memory. The two buttons you just programmed would continue to work.
Totally undocumented.
Hope this helps someone else.
post #2 of 2
Thank you very much for that coffeencreme. I will forward this to the appropriate department to see it we can have that added to the manual.
  Back to Forum: Remote Control Area
