AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Help with VIZIO XVT553SV remote
post #1 of 4
Anyone got any ideas for me on this little annoyance? Remote is paired/bluetooth and the "LIST" button is supposed to take me to my "Recorded Program List" on my HDDVR (Cox, Scientific Atlanta) but instead it takes me to Channel 1, On Demand. Called Vizio CS they put me on hold, escalated to level 3 and came back and said her supervisor told her "the remote is limited and will not perform that function" I politely asked them to open their manuals to page 15 where it says under LIST function "When programmed to a DVR this button will display a list of recorded programs" they then said "umh" and pretty much nothing else. So they were useless. I tried re-pairing and it does the same thing. Any thoughts? Thanks!
post #2 of 4
Can anyone that owns this confirm that their "LIST" button is performing properly?
post #3 of 4
My remote works as stated in the manual.
The set top that I have is Moto DCH series. The list button shows my recorded programs on the cable DVR and also shows the recorded programs on my Media Center.
post #4 of 4
Although I don't own the TV, my guess is that this function is implemented via CEC of HDMI. The "LIST" is probably the "Contents Menu" in CEC Command Set. So it works only when your DVR is CEC capable and understands this command.
