AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Lava subs
Lava subs - Page 45
post #1321 of 1325
Well, just to update, I have decided to go with option C...Do-it-yourself.
Made my first purchase today: Dayton SPA500.
Next is TC Sounds Epic 12", and then box and hardware.
Guess I'll be mozying on over to the DIY thread...thanks for everyone's help here. Eric, thank you for being helpful. If I had decided to stay with a pre-fab powered sub, I was definitely going with the LSP12.
post #1322 of 1325
Look here http://www.polkaudio.com/forums/showthread.php?136231-Dayton-SA1000-TC-Sounds-LMS-R-12-Dayton-3-Cu-Ft-Enclosure-Isolation-Platform
post #1323 of 1325
Sorry, link says I need 100 posts to view...
post #1324 of 1325
post #1325 of 1325
Hi,
I am new to this forum and feel little overwhelmed with the reviews of different subs, especially PL200/ LSP12/ HSU STF2. My budget is around $300 and all the ones I mentioned fall around that budget. HSU STF2 will be stretching my budget but may consider if it will give me the most home theater feeling.
I have Onkto TX-NR509 receiver, Polk Audio New Monitor 65T front speakers, Polk Audio 45B book shelf and 25C center speaker system. I play music and movies for equal amount and do play games on PS3 too. I listen to all kinda music, rock, metal, country music, R&B as well as some slow songs too. I don't have my room dimension as of now but I would say it's medium sized living room attached to kitchen so it does make it look big.
If I have to buy one which will give most complete Home Theater feeling irrespective of what i am listening, which one I should pick? Is anyone out here who has listen to all of the three subwoofers?
Thank you!!
