Jeff: We seem to have missed each other completly. "EQ" - AUDYSSEY is a needed tool that much improves the majority of my listening experiance. It is not optional for me either and is back on.
The fact that the unit can handle DSD and sounds wonderful in both stereo and multi channel gives me some hope for the format, if you get the chance give it a listen. Its 1 bit a 44.1kHz but that is what the spec says it should be... 8 channels sample rate 44.1 so be it I am getting what I paid for in terms of what is on the disk and it sounds very good indeed. Brovo to integra for providing the ability to take in a DSD stream.
When a product has a listening mode called "DTS 96/24" and says in its manual to use it to enjoy hi rez recordings up to 5.1 out (I will except the fine print at face value and reading if EQ is disabled means I will disable it and see what happens)...... and well the integra still tell you the unit sees the incoming signle as 96/24 and promptly samples to the dac at 48kHz
How about this.... lets put "EQ" - AUDYSSEY back in seems like we both need it and lets go get a qualirty DVD-A recording such as Fragile from Yes. As the recording has both a DTS 96/24 and a stereo 192kHz output available one might think hey now lets ignor that fancy surround stuff and go back to plain old stereo....... only you guessed it sample rate out DTS or stereo is 48kHz had to try them both after I could not get anything higher then 48kHz on the stereo mix.
Well now that's fine lets be honest DVD-A and SACD are to be frank dead so I will grab a nice Blue Ray.... DTS master out.... at 48kHz..... well that is a remix of an older DVD to be fair so Harry Potter last one in the series on Blu Ray we can agree that is modern enough to be mixed at something of a better sample rate when we get to DTS master right..... well wrong output is 48kHz.
Again, I can go over HDMI, I can go over SPDIF, I can go Bitstream or LPMC..... I can even set LPMC for 192kHz out with my trusty DVD-A recording and the Integra still says love the 48kHz.
Play a hi rez 2 channel FLAC and it will in fact read it and sample it at 24/96 kHz just as it will read DSD/DTS/DVD-A all correctly incoming and then promptly resample to 48Khz or basically what you could get out off a sub 100 dollar DVD player more then a decade ago. For a finale test I simple hooked up a pair of balanced cables, left the sub set to on and start to switch between the oppo as the decoder and source and the Integra..... and I could not hear what I would call a lot of difference.
My issue is not with Integra. Its a great unit, sounds wonderful and does just about anything I ask. My point is if.... and this is up to you but if.... you are going to go out and spend the extra money on that new Blu Ray release of the best new movie out there mixed in 24/96 Master DTS..... you really ok that under the covers its being down mixed to 48kHz. What if it took all those blu ray discs and dumped them down to 420p you ok with that..... you still buying the blu rays and the imports and the new releases of all those movies you have in HI DEF.
It not just about sample rates and input output, for me its about paying a premium for content and then basically not being able to access it.
My only point is that I am shocked that while I can play anything when I pay a premium for a new "hi rez" recording or even a movie you need to play really close attention to what is really being mixed at the head unit cause it may not be what you are thinking it is nor reflective of the premium you pay. Go pay the extra 5 bucks for an iTunes hi def rental then run it on your first gen iPad..... was it worth the extra $ cause iPad v1 does not do 1080 and you aint never going to see it on a 9 inch screen.
