Originally Posted by
pepar
I haven't seen any statements on this HDMI issue like I did with the frontpanel/IDE cable issue. On that one, they stepped up early and were very declarative.
Jeff
The following from the Integra FAQ's suggests that they may cover the HDMI issue outside of warranty.
I am not getting sound from the receiver and there aren’t speaker icons displayed on the receiver.
1. Perform a master reset. To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. Power on the unit to see if the issue is resolved.
PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY.
2. If the reset has not solved the issue then the unit will need to go for warranty service. If you are within you 2 year warranty click here to find the nearest service center to you.
http://www.onkyousa.com/locator.cfm
3. If you are outside of you warranty, you will have to email or fax 1. The model and serial number of the unit. 2. A copy of the receipt 3. Contact information. 4. A brief descriptive of the issue, to parts@us.onkyo.com or 201-934-7823 for review for possible service assistance.
