AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The Official Integra DHC-80.2 Pre/Pro Thread
The Official Integra DHC-80.2 Pre/Pro Thread - Page 128
post #3811 of 3823
For those of you who were out of warranty or bought it second-hand and had it fixed at a repair center, do they actually replace it with a newer HDMI chip? In other words, does the problem stay fixed?
post #3812 of 3823
@raukuen I bought the 80.2 back in November, 2010. I experienced the same issues that others have reported and sent my unit in for repair in June, 2013. Well, just yesterday, my repaired unit started to fail again - exactly the same issue. I spoke with Intergra's customer service and although the unit is technically out of warranty (by 2.5 months), they have asked for more information to determine whether or not they will cover the repair... So, the answer to your question, at least in my experience, is that it is not a permanent fix...
post #3813 of 3823
I'm on my second repair as well. That being said, the first repair lasted a couple years (sad commentary that I think lasting only 2 years was a good thing), just long enough to push the second repair outside of my warranty. So far so good at least these last few months...
post #3814 of 3823
@ Talking Rain
Congrats on ur 80.2! Here's a suggestion for you. Hit the home button on ur remote. It will give you a menu. Go into audio and you can add more bass from the various setting parameters for each speaker. Dial in what is to your best liking. Finally under the same audio menu, scroll to Dynamic EQ and set to "On" and scroll down to Dynamic volume and set to "Light." This works best in my configuration. I hope this helps.
Cheers!!!
post #3815 of 3823
Do they give you a 2 year warranty after repair only if you bought the unit from a dealer? I bought mine from Audiogon, I believe. And I was thinking too that this was going to be the last processor I buy because there's no other audio-related feature I could possibly need. I guess there's no escape from the hobby once you're in. Now if there are any similarly functional models without any flaws...
post #3816 of 3823
im from canada and my 80.2 is almost out of warranty no problems yet my question is does anybody in canada know how much a hdmi board repair will cost if it happens after warranty or should i dump it
post #3817 of 3823
Hi carstereoguy1, I just got mine back from a repair shop in Montreal. It cost me about 365$ with labor. I was out of warranty. The cost was too low for me to swap to another pre-pro. rolleyes.gif
post #3818 of 3823
BTW, I just got mine back from repair and not sure if anyone else noticed but it seems as though I have to re-calibrate my system. I'm setup with Front Wide's and my left speaker is super low. Here's the funny thing, when I'm listening to 2ch audio in direct, L+R seem balanced. When I switch the preset to Stereo, the R speaker is much louder.
Also, I watched a movie after getting back and the voices were very faint. I'm going to try and re-calibrate it. Not sure if changing the HDMI board messed up all the calculations and settings of Audyssey or what. I wouldn't think so. Just curious to hear about others experiences.
post #3819 of 3823
what repair shop wa it and i was talking to integra and they said that they would offer a one time repair free of charge even out of warranty how old was yours and bring it back to repair shop something isnt right thanks
post #3820 of 3823
Mine was purchased from a dealer on Audiogon - Refurb'd. I didn't bother calling Integra as I knew what the issue was. I brought it to a local shop in Montreal called NDG Repair. They work on McIntosh and many Integra units but was VERY dissappointed with their service. If your in Montreal, CAPRI is the official and all time best place to get it fixed.
post #3821 of 3823
how long before the faillure and what was the signs before it failled
post #3822 of 3823
Mine took a little under 2 years to fail. I want to say 18 months maybe a bit longer as I had convinced myself I must be out of the woods. Don't think you are good simply because it has held up this long. My first sign was no sound from my cable box which is a direct HDMI feed for both picture and sound. My DVD at the time used spdif out to the integra and as I recall went direct to the TV and worked fine. After cycling the box and the unit a couple times I got sound back and said ohhh... well must be my cable..... Happened 2 or three more times over the next week each event a bit worse as I recall it took longer and longer to get things back up and running.....and then one day there was no recovery no matter what.... if it went in HDMI or came out HDMI I had no sound..... within an hour I also had no picture no menu access and so within about a week it was packed up and heading off to be fixed. It did take some time and effort to get to Integra get the normal questions answered, serial number did I have an original receipt that sort of thing but once past the basics they were very quick and very professional. I was told that my unit by serial number was part of the overall batch that was known to have problems and I was also told it was indeed the HDMI board that failed. I will not fault them for trying to hide what was going on.
If it seems off and it seems to be with all things HDMI then you likely have a board problem but you really do need to check it out. Yes they fail and by all accounts they failed a lot, but they are not always the problem.
I have had mine back about a 18-24 months now and to date I have had a couple minor problems One that turned out to be the HDMI cable and it looked very much like it got stepped on or bent while trying to get it into the back of my unit. New cable provider and when he put in the new box I suspect he stepped on the old cable. It started with a lot of handshake problems on cable content within an hour of his leaving the house and I have to admit my first thought was here we go again, but I was wrong...... So before you assume its got to be the board do check the normal sort of things out, is it just one source, is it just a loose cable, I really thought I was going to have to send mine back in, but at this point I have 4 good HDMI only based sources (an Oppo, PS3 and a PC as well as the cable box) and all others worked fine with no issues so I narrowed it down to one bad cable. Integra will likely ask you to verify these things before you return so you might just as well try um first.
Mine is pushing 3.5 years and is out of original warranty but if the HDMI board does go again I expect Integra will either repair it or offer some sort of break on the effort. I did buy mine from a dealer I did provide a copy of the receipt when I sent it in and my serial number is now on file in their NJ facility as having the board replaced and that does seem to carry some weight with them. If you fall into what they know was the original bad batch via serial number you tend to get express service or at least I did compared to some stories I have heard..... Door to Door it was out of my hands just under 10 business days. As I recall they did promise to repair again if it went but I do not recall if it was for 1 year or 2 and at this point I understand from several posts that the replacement boards are either in short supply or can be at times. Even so based on my experience I would suggests as I have before either buy from a dealer or make sure the board has been serviced before you buy used. If I get a good 4 years out of the unit I will be happy and would likely buy again from Integra even with this known issues this was a lot of device for the money and in my book 4-5 years is about as long as one can reasonably expect a HT unit to keep pace. As someone above stated once you are in you are sorta in for the ride.
post #3823 of 3823
My 2 1/2 year-old Integra DHC-80.2 bought refurbished with full 2 year warranty from Onkyo started showing the classic signs of the HDMI board failure about 2 months ago, and things just deteriorated from there,
My best friend's Onkyo receiver purchased 3 years ago upon my recommendation had the same problem show up right before my unit and he took it to a local repair station that essentially charged him $30 just to inform him they could not fix the problem, so he emailed the closest Onkyo repair station in upstate NY and was told the repair would cost no more than $175; He shipped the unit and a few days later got the news the repair would cost him at least $300 plus return shipping charge, at which point he told them not to bother and do whatever they wanted with the unit. All of that for a receiver that cost him barely more than $400 offering excellent features such as Audyssey MultEQ XT and Marvell Qdeo video processing chip.
Based on his experience i decided to email the person whom appears to be the "point man" at Onkyo in charge of handling owners having problems with HDMI boards, Jose Torres ( jose.torres@us.onkyo.com ), and asked him how to best proceed with repairing my unit considering my friend's experience, that all i expected was a repair charge not much higher than $300 at a reasonable 2 ~3 weeks repairing time. He immediately emailed me back asking me for a copy of the receipt (originally emailed to me years ago and not available any longer) and serial number of unit, which i did and Jose emailed me back within 1 hour informing me he had arranged to have my unit serviced free of charge at the nearest authorized Onkyo repair station and to expect a call or email from them soon !
I was very/very impressed how quickly and decisively he took care of my concern, the consideration shown as my unit was already out of warranty and i had already expressed my willingness to pay for the repair and the fact that we emailed back and forth several times without any time concerns from his part, considering what i imagine is his very busy job position at Onkyo.
I certainly feel that Jose Torres in representing Onkyo / Integra brands the way he did in my situation went above and beyond what i expected and he must be commended for it : how many reps from consumer electronic companies show that kind of consideration toward customers with out of warranty units needing repairs ?
Jose told me he is there to help any owners of Onkyo / Integra receivers and A/V processors having these HDMI board failures and that anyone may contact him directly at his email address listed above.
BTW, right before i packaged my DHC-80.2 for shipment i noticed that "NETWORK" and "FIRMWARE UPGRADE" on the "HARDWARE SET UP" menu were greyed out, not available any longer; Three weeks ago i did a full firmware download/installation without any problems, my direct ethernet connection to router has not changed and internet connection is fine in desktop computer, so it appears that another problem had cropped up with my unit....Hope it will come back in fine working condition without any HDMI issues, including some that i lived with since installing the unit : often times my computer connected directly to the DHC-80.2 by HDMI cable would refuse to turn on until i physically pulled the cable from the input connection AND my cable box never / ever worked with the DHC-80.2 via HDMI direct connection, i had to use component cable connection...
PS : Got my unit back from repairs yesterday, one week after shipment, and everything is back to perfect working condition.
I think a turnaround of 7 days for repairing such "finicky" A/V processor like these Onkyo / Integra top-of-the-line units is OUTSTANDING PERFORMANCE and both Jose Torres and the company in Massachusetts that repaired my unit, Pinnacle Service Solutions, deserve a lot of credit; They even double-boxed the unit for return shipping !
I have had many/many pieces of home electronics repaired over the past 40 years of purchasing A/V equipment and the fastest turnaround i experience is about three weeks including shipment back and forth - longer for ground shipping from California to East Coast which takes about one week.
After this experience my faith in Onkyo / Integra customer care and warranty has been completely renewed, re-established, reaffirmed.
Marcos
Edited by MCaugusto - 4/11/14 at 6:50pm
