AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › LCD or LED that is the question?
post #1 of 10
Would this be the correct forum for this?
Were in the market for a TV, and I'm asking for suggestions online.
What to consider:
  • Most likely going to be used for gaming (Wii, PS3, possibly Xbox 360 (if Kinect gets a good tennis game))
  • Because it'd have a PS3 connected, it'd may see some DVD (netflixs or otherwise)/blue ray use.
  • It may have a DVD player of itself connected
  • Possible Netflix (PS3, Wii, or the TV it self)*
  • Most likely going under a fireplace mantel, IN FRONT of a fireplace. Though the fireplace doesn't get used that much. (Texas)
  • My personal preference would be a LED & a Sony. As a LED is lighter and thinner than a LCD, and if we have to use the fireplace we can just move the TV onto the carpet (might be on a stand). And I say Sony because I guess I'm just tiered of seeing the same or similar user interface for Samsungs, LG, etc.
  • We're thinking a 46 inch.
  • The PS3 might be hooked by HDMI cable along with RCA (possibly).
  • NOT a 3d (ready) TV.
  • Not to put down Plasma, but I am fine with a little lag, and also not the BEST picture possible.
  • Were fine with 720 P, we don't need 1080.
  • AT MOST possibly $1200
  • Seating -- I'd say a few yards, enough to play Wii games that involve motion controls (Sports)
  • Oh god the room I'm in (where the TV would go) has WAY too many windows. One is technically two, but has separate blinds and goes quite a ways up (enough to have to use a ladder to put the blinds up originally), the other is a taller but narrower window. I may try to get pictures, but it'd be about a week, on the other side are two doors that lead to the backyard, they have glass in them and besides each are two more windows. There'd be PLENTY of light.
*Could anyone tell me (with a internet enabled TV) how netflix works? Similar to how the discs work for Wii & PS3?
post #2 of 10
I have the Samsung 46" 6000 Series LED TV and I Love it!! Judging by your list of requirements and non-requirements, I'd say this TV will fit your needs just about perfectly. You'll have the 1080. I mean, if you're going 46", why wouldn't you? It's thin and light for moving off the mantle for when you do have a fire in the fireplace. It has game modes as well as other modes for watching movies etc, which will allow you to adjust for the amount of lighting you'll have.
A quick cursory look at prices at Frys for this TV showed the price around $1500, but shop around and you might find a sale.
As far as your netflix question goes. If the TV supports it, you'll be able to stream movies from your queue directly to the TV, but you've already got the Wii, and PS3 that will do the same in addition to playing the actual Blu-ray disks.
You've got a lot of connected equipment there, not sure if you've thought about internet connectivity for all of your devices. I just reviewed a neat device from Netgear that will save you the hassle of running wire to your home theater just in case you aren't already pre-wired. Just posting this in case you haven't thought of it or come up with a solution, this is a neat device and it will work great!
http://www.homesystemintegration.com...ut-the-hassle/
Hope that helps!
Tom
post #3 of 10
LCD and LED is the same damn thing. It's just that the backlighting which is different. Get the standard LCD as it'll be cheaper.
post #4 of 10
To be correct, your poll should ask CCFL or LED. Both are LCD's; the difference is how the panels are "lit."
Also, you say "were" in the market for a TV. Does this mean you already bought on or do you mean "we're" in the market for a TV, meaning "somebody else & you?"
I think it would be much easier to respond to your poll if you had specific models for each manufacturer rather than just using "generalities" for your poll selections.
All of that being said, I'd pick the Samsung UN46C6300 from stores like Best Buy, HH Gregg, or Fry's OR the Samsung UN46C6400 from Costco or Sam's Club (pretty much the same TV, just a different model number).
post #5 of 10
ccfl LCd ---- Edge Lit led LCd ---- Local Dimming led LCd
post #6 of 10
I would pick the Sony. The EX500 will give you great value and the functionality is the same as the PS3. The same remote could also be used to operate the PS3 and EX500... Bravia Sync simplifies things a bit. The only con is the weight of the conventional LCD.
I'm a little behind and noy up to date on the performance of the Sony LED sets, but the EX700 LED didn't get as much love as the EX500 CCFL. But with that said, in a brightly lit room, the deficiencies of the EX700 would be totally unnoticeable.
Another reason to select Sony - the matte screen diffuses reflections and glare, the Sammy will be mirror-like. Also, at 46", 720p is ot an option on LCD, only for plasma.
Go with your personal preference... you won't be disappointed.
post #7 of 10
We have wi-fi already, connectivity isn't much of a problem. Our 32" Samsung that was in here got stolen a few months ago and it should be replaced.
I say 720 is fine because the last TV got mostly used for Wii games, and even when DVD's were played, no one in this house could tell a difference (if any) . . . .
I also don't have a PS3, YET, I want one.
post #8 of 10
Any other suggestions for TV's? And since Samsung & Sony have gotten the most votes, what TV's of those companies?
post #9 of 10
Keep in mind, most internet ready TV's require a Wifi USB dongle. If you buy their proprietary dongle, expect to spend another $50-80. Direct (wired) connection is the best/cheaper way to go, if its possible.
I went wired in my livingroom, as my modem is right next to my TV and spend the $60 for a dongle in my bedroom.
post #10 of 10
For the distance the cable would have to do I think it'd be better for wireless. Other votes? Other suggestions? Models? Brands?
