I currently have a 9 year old 53" Sony KP-53HS20 rear projection TV in the family room. It's time for an upgrade.
The screen size I'm aiming for is in the 60" range with a preference for 65". There would be a mix of watching HD-content and gaming. 3D is not important for me at the moment. I'm trying to keep the cost around $2500. I plan to make the purchase around late November - early December.
Models I'm considering:
I also plan to buy an integrated mount/floating TV stand. The Z-Line Designs Sync stand (ZL788-50MvU) looks good and supports up to 150 lbs for the mount. Anyone else have experience with this stand or this brand in general? Any other alternatives out there?
Couple of questions:
- Panasonic P65VT25 - Beyond my price range and I don't think it'll drop substantially in the next couple of months (please let me know if I'm mistaken).
- Samsung PN63C8000 - Just slightly above the price range at some stores. Looks slick. I've read that numerous users are having buzzing issues so much to the extent that some are considering returning it just for this issue alone. Screen size is 'only' 63".
- Panasonic P65V10 - No 3D but not important. Comfortably in my price range and hopefully will drop even further by the time I make the purchase. I'm not really a videophile so I hope the rising black issue won't be a big deal for me.
- Any other major pros/cons and issues I should be aware of for these models? Any other models I should consider?
- Can I expect some attractive price drops around November-December?
- How exactly does this Samsung buzz sound like? I know it's directional but what sound can you compare it to? I found some audio clips of the buzzing sound and it sorta sounds like an electric razor in my opinion but from the clips it was hard to separate what was buzz and what was background noise.
- Is the 63" and 65" difference significant?
- Should I consider models outside of plasma?
