Originally Posted by stimperley
Guys,
I got a new 46" as a replacement for my XBR2. The corners (3-4 inches out) are all brighter in dark and light scenes. I'm pretty disappointed to say the least. I checked out an EX700 (I thought the picture would be pretty similar) at a local store and it had minimal bleeding of light from the LEDs and I was able to live with that but the 710 I received last week is horrible. I don't care how much you turn down the backight either, it's just ridiculous. I've sent another e-mail to Sony about it. I'm sure they are getting as tired of me as I am with them. Is it too much to ask for a TV that you can just watch and enjoy?
Sony is ordering another 46ex710 for me and going to do an exchange. I'm hoping this next one will be better but only time will tell. They did say if the next set had the same problem to call them right away.
This TV seems to have a pretty exact "sweet spot" although the "flashlighting" or whatever it may be called is more prominent on the left side of the screen. I understand this is an "entry level" TV but the picture leaves quite a bit to be desired. It does seem to do a pretty good job with sports or fast moving scenes though, I don't really see too much motion blur like I have in some of the 60hz lcds.
When my XBR2 was up to snuff you could sit closer and at more angles and still enjoy the picture. I'm by no means trying to compare the two but I would think that a TV that is 4 years newer should be able to do a little better job than the one I received. My family and I want to be able to enjoy this set but we unfortunately can't sit in a straight line one person behind the other to get the best viewing experience. Sorry for the rambling, just my thoughts so far...
Guys,
I do have an older copy of DVE ... hasn't got all the HD goodness on it. I should be able to get good results at all resolutions as long as I feed DVE the proper SD signal when calibrating the set?
