I have a 36 inch sony Trinitron SD set. When I feed it by rf (remote dish box) there is a break in proper convergence in the upper right hand corner.
When I feed it by RGB, a Sony HD box to the SD set, the picture is perfect, and there are no convergence issues in the upper right. Actually, it's a really amazing SD picture.
Any ideas ? The set is otherwise OK, although I've not "tuned it". When playing a DVD (by s-vhs input) the letter box is not perfectly straight (I"ve used the adjustment in the setup menu.
