What I mean't was a higher quality A-Lens is required for 3D to provide an acceptbly good image, where as for 2D the quality point may not need to be as high for similar results.
Re the CR remark, I notice the JVC's open up the iris to max thus lowering the on/Off CR in 3D mode so maximum light can be produced.
I was just wondering since the visual depth is created by the two frames, if a high CR is perhaps not as important for 3D(though it won't hurt!) as it is for 2D.
