These are links to the builds I made. Most people won't need the extra storage drive, but my NAS drive died right before I made this build.... hence the HTPC/NAS I use this for now.
Mini ITX i3 Build
This build will cost around $725 from newegg today.
Mini ITX Zotac E-350 Build
This one cost around $575 for the complete build off today's prices of newegg.
I was aiming at a $400 build... but like always it cost way more then I wanted, but I am extremely happy about it. I built the Zotac build off Newegg TV: Mini ITX HTPC Build Series. Great video on two basic builds and along with assassins guild helped me build my first HTPC (but not my first computer). Moving on for extenders and such I think I will keep it to a $300-$400 G620 intel build. I was not too impressed by AMD.
A few custom mods I added to the case:
Panel Mount USB Cable
Vantec Thermoflow TF8025 80x80x25mm Double Ball Bearing Temperature Controlled Case Fan
StarTech USB A to USB Motherboard 4-Pin Header
IO Crest Dual 3.5-Inch HDD/SSD Mounting Bracket
Just screwed the fan into the vent holes where the vertical drive would go and moved the drive to the bottom front of the case where there is empty space.
Mini ITX i3 Build
