AVS › AVS Forum › Video Components › Home Theater Computers › Help with mITX board for basic HTPC use
post #1 of 14
I've seen some spread out threads but nothing concise and nothing recent.
I'm looking for something relatively new that I can either build or buy that will fit the following needs (basic IMO)
1. Playback of 1080p content with no stutter (all MKV no physical media)
2. Virtually silent. No fans if possible but quiet if I need. I can put in an SSD
3. Very small form factor. Assumed I would need a mITX board but open to opinions.
4. Plays back flash content with no issues
Like I said, nothing revolutionary. I'm currently using a Atom N330 through Win7MC and MediaBrowser and for the most part it works well (haven't tried flash yet) but it is a little slow at times. I would like something snappier. Since I need to put a HTPC at a new TV I figured this was the time to ask.
Thanks for the help
Josh
post #2 of 14
Thanks for the help
Josh
Have you checked out the sticky thread?
http://www.avsforum.com/avs-vb/showt...i-ITX%20System
post #3 of 14
If you want snappy, the i3-530 is really nice. renethx's Mini-ITX Intel (iGPU) system should work quite nicely. It even handles the occasional transcoding job with ease (e.g. DVD -> iPod/PSP). One nice thing about it is, barring future 3D implementations, it should be more than fast enough to handle videos even without hardware acceleration. Alas, the issue with 24p doesn't seem to solved still. If you're affected by the issue, though, you could always install a discrete GPU.
post #4 of 14
I don't have an issue with the 24p, so the Intel DH55JG has been great for me.
post #5 of 14
Forgot to mention with the Intel i3-530 CPU.
post #6 of 14
Except I doubt you'll be able to find it for sale. The model number for Intel's board is DH57JG.
post #7 of 14
Thanks for the info. On those systems mentioned what is the noise level on them? It's going to sit in my bedroom so I'd like something very quiet.
post #8 of 14
This http://goo.gl/ULT5 ?
post #9 of 14
Thanks for the correction. I have 3 different builds using DH55TC, DH57DD and DH57JG. Sorry for transposing the model numbers.
post #10 of 14
I have the DH57JG in a fanless case with a SSD and no optical (reads movies off the server), so the only noise to consider is from the CPU fan. So far, I've stayed with the stock fan from Intel that comes with the i3-530. My plan was to upgrade to a quieter fan if necessary, but I dont notice anything. A number of people upgrade the CPU fan, but I get the impression that most people just stick with the stock fan because it is quiet enough.
post #11 of 14
THanks.. That's a huge help.
post #12 of 14
Do the requirements go up for the HTPC if I want to put in a BluRay player to play physical media? Up from the I3 I mean.
post #13 of 14
No. My two other i3 machines have a blu-ray drive and each works with no problem playing bluray from the optical.
post #14 of 14
Thank You
