I had some help from BPAPE a while back but I'm now getting to the point of doing the soffits. My soffits will be constructed completely within the GG/DD/clips enclosed space. Their purpose is to hold enclosed HVAC runs, a light tray, a ledge for rope light, hold all speaker/projector wiring and bass trapping with any open space after all that.
I made a 2D sketchup cross-section of how I plan to construct it. For the HVAC enclosures MDF was suggested but I'm considering switching to OSB sandwiched with gypsum board and a layer of green glue. This picture shows the minimal width section. Some parts of my soffit will be wider with constant width light tray.
I've color coded the picture:
Yellow - OSB
Green - gypsum board
Tan - lumber
The red L-brackets are Simpson Strongtie angle brackets. I used those in place of ripped 1x lumber to leave more space in the HVAC enclosure.
The ripped 2x4's will be screwed and glued to the ceiling. The OSB sheets adjoining the lumber will be screwed and glued to the lumber. Will this be strong enough?
I'm still a few weeks away from doing this, so I wanted to see what the experienced builders here think of my plan. Have at it.
Sketchup file is in the ZIP.
Yellow - OSB
Tan - lumber
soffit cross section.zip 47.466796875k . file
