Originally Posted by Grey_Fox719
Well here is where I panic. I checked the time that the TV was on and it was at 639 hours. And I am getting I guess image retention almost everytime I play a game. I let the color slide run all day, and when the red slides comes in "BXTV" is clearly readable, but thats the only time I have seen it. Should I play on the "Game" picture setting, and I am VERY insane about my electronic toys and and SUPER careful not to let it sit on a menu for any extended period of time. Example, I played Dead Rising 2 on the THX setting for 2 hours, and after 6 days the "Killed" From the total zombies killed counter is just now starting to fade. And maybe its because I am sitting too close to the set (I am in the Barracks) but I see "Noise" or almost static in the image.
You might be sitting too close and see can see more pixelation. But if it's white noise flashing in spots at random, check the cable or reseat the input connection. Also, check the game system's resolution setting for good measure.
As for the IR, play with the pixel orbiter settings in the TV menu. Also, you could always try using a snowy signal instead of the scrolling bar, it might remove IR faster.
My calibrator said the GT25 was very similar to the G25 so that is confirmation for you. You might try a calibration disc to get the picture dialed in more to your liking.
