AVS › AVS Forum › Video Components › Home Theater Computers › s3 wake up log
s3 wake up log
post #1 of 6
so, is there a way to log what wakes up my computer from s3/sleep?
it can't go a night w/out something waking it up.
post #2 of 6
Download Standby Tracker and let it run. It runs in the background and tracks wake up and sleep events
post #3 of 6
Link? Google returns nothing
BB
post #4 of 6
I'm going to assume you're using Windows 7, but you can run this command to see what might be waking it up.
1) Open a command prompt
2) type powercfg -waketimers
Again, assuming you're using Windows 7, you can also open the task scheduler and it should also tell you what is setup to run automatically on your system.
post #5 of 6
FWIW, my wakeup problem was due to Windows Media Center downloading guides. I turned off the feature.
post #6 of 6
BB
true story
