AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › aspect ratios
aspect ratios
post #1 of 2
This seems such an obvious question, but I am a complete newb to HD and Blue Ray and can't find the answer anywhere. Why am I watching films in a 'letterbox' area on my HD telly even with a blueray disc? I bought a decent full HD screen, a blueray player and subscribed to LoveFilm, thinking that I would now enjoy films at their best. But I cannot get full screen. I am using HDMI cable, the screen is set to full HD 1080p, the player is set to 1080p. If I try any other modes the picture is distorted, everything is tall and thin. I contacted LoveFilm to ask what aspect ratio their discs were, having in the back of my mind a vague idea that you could get different formats with discs, or was that with videos? Their answer was that it must be a setting on my equipment. Well I have looked until I've got a headache but cannot see any clues as to what's wrong. It seems to me that high definition can only be called that if a certain resolution is used, but if the entire screen is that resolution, then using only a part of it means only a part of the available resolution is being used so it is no longer HD. That's logical isn't it? is it me?
post #2 of 2
It's you. There are many different aspect ratios for films. Your display is a fixed size. That means that different aspect ratios will appear differently on your set. It is still HD if the source is HD. See this: http://en.wikipedia.org/wiki/Aspect_ratio_%28image%29
This thread is locked
