hello,bought a new DP42840 last night and set it all up.When
watchin
the tv,the screen goes black for a second,then quickly goes
through the
picture settings(vivid,standard)then goes back to
normal...its good for
a few minutes then does it again..it is connected via hdmi
from high def
motorola box with hd signal.....is there a setting for
this,or should i
return it.
also,when i have the menu on,it does not do this,but the signal in the background does
thx
watchin
through the
from high def
this,or should i
return it.
thx
