Originally Posted by
Kamus
So you're saying my arguments hold no ground, and his do? You haven't even seen the projectors yet.
All we have to base our opinions right now are the spec sheets. and guess what? they are almost exactly the same on all 3, with the only significant difference being on/off contrast ratio and of course the CMS.
and the CMS isn't that big of a deal if the now included HDTV preset is close to the standard.
on all 3 models we get:
-The same new shorter arc lamp with the same brightness.
-Same panels
-3d support (for anyone that cares)
-the improved FI (for those who care)
-cinema filter
-An accurate HDTV color gamut (jury still on how good this will be on the X3, but that's what many people have been told from JVC)
So, what we're missing with the X3 is:
-CMS
-Pure wire grids (at least i think so, based on what i've read) for extra contrast.
-What JVC calls "advanced lens aperture"
So really, if you got the cash to spend more than twice the price for an X9 vs an X3, good for you.
I'd love having those features myself.
But how can you suggest that my position makes no sense?
It makes perfect economic sense, you get almost the same performance (based on specs) for less than half the price.
Again, not saying that you shouldn't do what ever you want for your money. But to suggest that it makes "no sense" to pick an X3 over an X7 or X9 makes, excuse the redundancy, no sense what so ever, since it delivers the best price / performance ratio.
Once the reviews are in, we'll see if the X3 can hold it's own vs the X7 and X9.
But if JVC delivers what the specs sheets say, it will not only hold it's own vs it's expensive brothers, but the difference in PQ shouldn't be noticeable for most viewing material.
I mean really, the biggest problem with previous JVC entry level projectors was the lack an HDTV gamut.
With that problem gone, the new entry level models are all of a sudden a LOT more attractive than it's predecessors.
and i strongly doubt that anyone will feel that they should have spent more than twice the cash for an X9 if the X3 delivers JVC's claims.
